Hi Angcl
I tried taking a single ended output in this way, but got a distorted and noisy signal. This was using both Legato and another low impedance I/V stage- i.e. using the DAC in current mode.
No idea why this should be, so it might not persist if you use the DAC in voltage mode. But I certainly understand your reasons for trying it, if you have an SE amp- it avoids the subsequent need for a extra balanced to SE converter stage, keeping the signal path shorter
Paul N
Paul N
"Flat cable crimping tool" would be the tool you search.It's necessary some tool to connect the cable?
ttp://www.cablestogo.com/product.asp?cat_id=1435&sku=04597
Some says two wood block and hammer is enough,,,,
That is what I use. Cables can be recycled from old IDE cables...
Yes is you use only a single end of the DAC output you will be throwing away quite a lot of what gives it incredible dynamic range. But you can do it if you like, just remember the DC offset so you will need an AC coupling cap.
Sorry what I meant was that I have never heard balanced Hifi as better than single ended.
Hey guys, just because I know many of you will need it soon here is the sidecar schematic.
Not much to it.
Thank you Russ.
If I have the need to cable between the output stage and DAC module, what is the longest cable I can put without compromising the sound?
Regards!
3.782 inches.
Just kidding. There is no way to know with the information you shared.
It will also depend on many factors - like how well you dress your wires etc. The type of output stage will make a difference here too. So the only honest answer is you will just have to try it out and see if it works well. If you find your picking up noise or something you will have to try again.
- More Vendors...
- Twisted Pear
- Buffalo III - flexibility without compromise.
