In the next month or so. I am planning on ordering them soon, then we just need to give them a quick test.
Thanks for quick reply. It's important to me, because i dont' have enough room in my enclosure for 4spdif board.
Can you tell me dimensions of this little 1spdif board? It will be stacked over another board (B3) or not?
I believe the single SPDIF board has the same footprint as the old B2 board, so it should stack nicely over your B3/IVY stage.
SPDIF Board Layout
SPDIF Board Layout
You are thinking of the S/PDIF receiver module. This board will be quite small; roughly a third the size of the 4input module.
We keep the moderation to a minimum, but in this case a post was deleted because I had directed that that sort of post should be in its own thread, and I gave prior warning.
I also do not happen to believe it is good information because it does not jibe with prior measured nor experienced results.
There is no other reason beyond that.
LEDs
Hi
I am soldering the components to the BIII and other boards. Now, shouldn't the LEDs '+' (the longer leg) goes into the square pad? But on the silkscreen, the flat side of the LED is the '-' of the LED. I have now soldered all my LEDs '+' to the square pads when I noticed the flat side of the LEDs. Should I reverse all of these??
Thanks.
Hi
Thanks.
I had BIII and 4-Channel S/PDIF (or AES-EBU) Input Module ,not sure how to set the SW1 & SW2 ? leave it as factory defualt ? all off mode ?
Did you try reading the manual? I found all the switch settings were in there.
Anyone know that the stock heatsinks of LCDPS were bigger enough to cool down the regulators? It was very hot after 10mins with BIII + 4-in-1 switch connected. I worry that the high temperature will cause damage on other components.
What's your AC input voltage? too much dropout voltage difference will work but very hot.
I using 9v x 2 15VA transformer which I measured ~10.2v AC on each rail.
Have you measured the temperature? LCDPS should be able to handle the load. As long as you are below 55C or so your in very good shape. If your above that I would use a larger heatsink.
Rule of thumb (or finger ) for casual temp measurements... at 60C, you should be able to touch the heatsink for about 2-3 seconds before having to pull away.
I haven't any equipment to measure the temperature. I could able to touch those heatsink 2-3 secs, just feel very hot, but it wouldn't hurt me.
I just worry about the high temperature will shorten the components's life.
p.s. today I bought two heatsinks which like the stock one but double the height, hope it can solve the problem.
- More Vendors...
- Twisted Pear
- Buffalo III - flexibility without compromise.
