GM said:I thought we were discussing optimizing driver micro-dynamics here, which no amount of box tweaking will directly affect, only the amount/type of stuffing used.
EnABLing the box only affects micro-dynamics to the extent that it reduces the box edge diffraction signiture.
dave
ronc said:So the general statement is a piece of wood or laminate or Mdf or a paper cone can support a transverse (shear) or surface wave?
ron
Edge diffraction from a wave traveling along the surface of a front baffle is pretty well supported.
dave
My point exactly. There is a great difference between a wave travelling thru a material and a wave travelling over a surface. In physics a paper material cannot support a transverse wave nor can wood or the like. I tried to introduce a shear wave into lead once and despite frequency or incident angle i could not. Its all dependant on density and elasticity.
ron
ron
Now this is just a logic question.
1: How can any material have an effect with an effective height of 2-10 mm on a wavelength of > 1 meter?
2: If its truly a transverse wave in the material ( i cant see how) then the dia of the emitting surface is the limitation in wave effectiveness.
3: once the wavelength is > the effective dia of the transducer, how can any reflectors/absorbers be effective.
I truly havent studied the assumpution, this is just purly first thoughts.
ron
ron
ronc said:Now this is just a logic question.
My spider sense is tingling...
