Bridge or Parallel?
GainClone Bridge or Parallel? Which one sounds good? The following are the combinations possible. I am confused which one to choose.
1. Bridge connection
2. Parallel connection of two inverting
3. Parallel connection of two non-inverting
I have been reading a lot about GainClone LM3886 here. I gather from other's opinion that Inverting always sounds good. The confusion is that if that is true then which one will sound good 1 or 2?
Now I have all the parts to build my dream project, the reason why I became member of this forum. I plan to have both buffer and DC-servo in the circuit. I am reading the application notes AN-1192 also. But it will be helpful to listen to experienced people.
Looing forward to your suggestion.....
1. Double the volts but if your speakers impedance dips - current starvation. Bridge + parallel is a better plan.
2/3 Differences between invering/non-inverting are a bit exaggerated. Parallel is very likely better with 90% of 'modern' speakers. Precise matching of resistors and offset trimming are a must.
Buffered is probably fine if you can build a good buffer. Servo is simply not needed with these chips. If you have input offset rather use capacitor/transformer than a servo.
Thanks analog_sa for your reply. At the moment I am just reading and reading in different threads. Here is a rough plan of my stereo Gain Clone design for one chanel.
1. Parallel of two inverting LM3886TF design with 0.1% resistors.
2. DC-servo using AD8620 or LF412. Though people say that DC-servo is not necessary, but all the good designs have them.
3. Separate buffer for each inverting stage using OPA627. This is somthing new I am planning which I have not seen before.
Any suggestions or opinion are wellcome...
Once I am finished with the circuit I will post that in the forum for opinion and corrections.
I suggest you look at the app notes in the data sheet for the LM4780. In particular the THD+N graphs comparing bridge mode with parallel mode. You will notice the parallel arrangment has worse THD+N in almost every case. I have no idea why - maybe the inherent symmetry of the balanced topology helps eliminate crossover distortion ?
At any rate, thats why I've chosen to build using bridge mode.
Franz G said:
... I recommend you a t-network for feedback!
Franz
Thanks for the suggestions. I will look at t-network and the app notes of LM4780 and get back soon. The application notes AN-1192 suggests that the best design is first parallel and then bridge. But I do not want to build so big a amplifier at the moment. And then I got confused about choosing from bridge and parallel.
I am sure, it will be an advantage with the t-net even with bridged and/or paralleled amps, as the chips have the same parasitic capacitances.
Edit: I just had a look into AP1192: the t-net seems specially interesting for the bridged version: with the t-net you could use the same input-Z for the inverting amp like the noninverting amp!
This should boost the quality of an bridged amp!
End of Edit...
You will not be disapointed about this detail!
Franz
I have looked at the datasheet of LM4780. I think the following two procedures will give different performance:
1. parallel connection of two separate inverting LM3886.
2. parallel connection of two inverting amplifiers (equivalent of LM3886) in LM4780.
The reason I feel is the length of some paths will be more in 1 than 2.
End of Edit...
Franz
I just noticed a thread on t-network. Have not yet explored it fully. Many many people seem to be interested in t-network. I will also try it in my circuit and post here the result.
Thanks for telling me about it.
A curiosity: feedback resistor should be as close to the chip as possible. and the track to it be as short possible. even using SMD is suggested. I am just wandering that using a t-network will make both the track and the total path length more. will a t-network also solve this problem of closeness; I mean with a t-network one need not bother to make the path length least possible. I am now thinking of a t-network with SMD.
Block diagram of my design
I am posting the block diagram of my gainclone design using LM3886.
More details schematic will come soon. Please have a look and give me your suggestions....I will include acknowledgments and thanks to all the people I got help and suggestions form when I post the detals schematic....
I am following the application notes AN-1192. Yeah, I will try the circuit without the DC-servo also. I see in AN-1192 that in the case of parallel of two inverting design the cap between buffer and the amp is used only when there is no DC-servo. I think that is what you mean.
regards
no mistake found so far...it seems....so i can go ahead and build it. this is the only way i can test it since simulation is not possible in my computer.
here are the people i would like to thank for helping me directly or indirectly....
analog_sa, ashok, Franz G, TwoSpoons, carlmart, richie00boy, peranders, gmphadte.
Upupa Epops said:
Only little notice : Input buffer can be common for both amps. Voltage divider on output of servo is too high - give there ten times lower value - 4K7 and 10 K. :cool:
i am experimenting with separate buffers. i know this makes the circuit expensive to build. but i have all the ics needed, so i will try. thanks for the suggestion about voltage divider resistors. i reduced it according to your suggestion. a little update of the circuit is attached. i will have lm338 regulated power supply for lm3886 and lm317/lm337 regulated for opa627 and ad8620ar. the power supply design will be posted shortly.
still waiting for more suggestions/corrections before i design the PCB.
