Boss Audio REV 3000 in protect
would these be the driver transistors?
32 ohms is low but not enough to blow a fuse.
With the current limiter inline and the amp powered up (including remote), what is the current draw?
With the limiter inline, what is the DC voltage on the gate leg of each of the power supply FETs?
Does the current draw change when you probe each of the gate legs when measuring the voltage?
ok we have a question when hooking up current limiter which is 10 ohms because the 2 one ohm resistors i have are 10w and not 20w , all i could find to add to it was an 8 ohm 20 watt so we added it to the 2 and when we check voltage across power supply we get 13.9VDC but when connected to the B+ on amplifier we get 2.0vdc across B+ and negative
