After 3 varnish layer. The bosoz will have the same traitement
Marc
Marc
Re: Zenquito amplifier
Luke,
I've bougth end 2003 the recommended FEt and my 5 amp carte are implanted after FET matching.
Luke said:Hi,
I have some 2sk1530 and 2sj201 and wondering if they would work on this amp, would save a bit of money and I suspect they would work.
Also struggling to get input fets over here or australia, anyone know of readily available substitutes?
cheers luke
Luke,
Banned
Joined 2002
JasonL said:
If its possible.........Yes Thanks
Banned
Joined 2002
My 5ch amp finished, i work on my bosoz. It's near the end to. All électronics are finished. I m working on case, and wiring.
I have to replace the wood bottom with un steel one.
Marc
Marc
Drilling, ever and aver drilling that's one of the secrets on Diyaudio
Marc
Marc
promitheus said:Tell me about it.
I thought after a while that it had only with metal work to do and nothing with electronics.
but at the end you make something nice and you forget about the hard work.
Nothing to add, you say all what must be say. In this project most time is spend in building the case......electronic take about a day only.
Marc
After some more painting works, connectics take place on the rear panel. Definitif PS wiring take place too.
Marc
Marc
I finished yet the definitif wiring of the bosoz
Some more détails pictures
It's too late in the evening to have a first listening, so it's for tomorow. I have to finish top screwing and varnishing too
Marc
Marc
- Bosoz in progress
