I don't know, i made so much tries and tests in a 2 years time that i no more remember them all...
Here are some clues:
- 7963 input tubes are a MUST, but you need a 33khz bass pass filter, as i said, and somewhat warmer output tubes. Anyway, i find that high transconductance tubes sound best at input, E88CCs (or CCas) are very good too. Keep 7963/E88CC input tubes voltage low (between 70 and 90 V) and current high to have a more relaxed yet very natural and wide sound
- I use a Janus PSU, to use GZ32s i had to adjust some cap values onboard. Snubber at every AC input (instead of caps) give some slight more balance
- R-core transformers are better sounding than toroidal or EI ones, upon my taste
- I filtered B+ supply using a pair of Tentlab electronic chokes, B+ is now absolutely more clean than using anything else (excl. real, but BIG chokes)
- Output caps are most important, i found Duelund to be the best, Audyn True Copper as second. I know Duelunds are very expensive, but you'll get a (many) thousand dollars sound using them
- LCR Polystyrene caps or Amtrans AMCHs are both very good in pass bass filter (C5 and C6)
- Mills resistors are very good as cathode resistors for output tubes
- For input tubes i use 2 x rechargeable D batteries as cathode bias, without resistors or CCS (1.35V are ok for 7963). IMHO the best sounding are Panasonic Cadmica, that are Ni-Cd; but if you prefer Ni-Mh ones, Imedion are very good too, a little harder but great energy
- Output tubes need grid stoppers if you want your Unbalancer to be silent even using high transconductance/mu tubes on BCF. You'll have to cut 4 traces to do that. 1k to 10k values are ok, use z-foil to avoid colorations.
- Grid stoppers have to be 1k on input tubes, too
- Better use Buffalo's own as volume control, instead of an input potentiometer/attenuator (unless you're ok to spend half a thousand on that at least). I added a battery powered Clone Note LCR passive between Unbalancer and power amplifiers to get rid of any unwanted noise (not needed using output tubes grid stoppers) and to keep ES9018 bit resolution at max even at low volume. I use a remote volume control/input switch board connected to Buffalo III, so that i can adjust volume and switch inputs using a remote; Clone Note sets the max volume i can reach. N.B. selecting inputs by remote is not so straight forward to implement even using a remote input select board: you need some OTTO II boards and some relays, as boards are made for switching between analog, not digital sources
- Battery ground tweaks can expand the space between upper and lower extremes, but they have to be well sized. I found 6V lantern batteries to be the best, coupled to 10000 uF caps and 1 uF Epcos metal grey MKP bypass. Effect is greater if you connect them to Buffalo outputs instead of Unbalancer outputs. They give great bass anyway!
- Buffalo's output grounds have to be connected to chassis using a DEN/DENO ground wire choke to keep noise to zero. No floating
- A 10/20mH common mode choke grounded via a pair of x7r caps helps reducing heaters ripple too. I don't use heaters elevation, as B+ is around 100V
- I find direct I2S input to Buffalo III from an I2S output player to be the best sounding solutions for input. Even better than good XMOS USB transports. I use a Raspberry PI connected to Buffalo's I2S inputs, with Squeezelite onboard, driven by a small HTPC running LMS. TPA's own Chronus/Rhea solution using BBB seems to be better still
I forgot:
- I/V resistor have to stay below or equal to 50R. Using medium mu tubes like E88CC or 7963 you even 20R resistors can be used
- Using film caps across I/V resistors as Broskie's suggests in some Unbalancer-for-current-dacs schematics enhances sound and smoothes dac output
By the way...can you share how you habe setup the Janus ? 1k5 in series ? That gives quiet a voltage drop as we need about 48mA*1500=72V ?
What Capacitance if any do you have after the Janus ? The standard Crcrc of the unbalancer ?
Thx a lot
Janus 1k5 resistor value cannot be changed: it has been calculated thoroughly and changing value would make noise rejection less effective, with hum appearing. You have to provide enough secundary voltage taking into count the voltage drop across it.
On Unbalancer i have 0,68 uF film + 2x520uF electrolitic + 2x1uF film bypass; r12 resistors are replaced by 2xmec50 chokes, each with its 2x47uF electrolitics.
I went a quite abundant to be sure to block any minimal ac noise.
Well, have you found this: Tube DIY Asylum
...I guess you canchange tubes and as well values...will do more research...
I have found a great intro on duncan's psu designe from dhtrob.com...trying to calculate a psu which is fast with small uF and good hf isolation...as the janus would have killed the ripple already...
What is said in Audio Asylum thread van be said about any unregulated psu used to power tube circuits, but they work very well and better than regulated ones in my opinion. Not everything can be espressed as ripple, dip, spikes and the like.
I tried ss ps with Unbalancer, but Janus sound has that "something special".
N.B. i tried other values for output resistor, but all of them led to heavy hum. 1k5 is the only one that seriously kills noise.
I can see why...this resistor needs to be 1/gm, so indeed when not changing the tube as well, no chance to change it. Although some people did simulations and reported that the Janus is anyhow quiet sensitive if not the right operating conditions are met in current, voltage, transformer regulation etc.
My plan currently is the following:
- I will have the tube rectifier on a seperate small experiment board, so I can switch types of rectifier to play with...e.g.Mesh RGN1064 or rgn 364 or 6d22s etc.
- I will design an Choke-input PSU, so omitt the first cap on the unbalancer pcb and have a choke instead of the first resistor of the first crc. I have always used there a choke anyhow but with 30uf-20h-47uf). Need to calculate now if it is good enough for choke input (has currently 20h with 550 ohm and 100mah capabilty, but not sure if is gapped).
- than no resistor for the voltagesetting/channel separation of the unbalancer, but two cables go from the pcb where usually the last R of the normal CRCRC of the unbalancer goes. This prefiltered B+ now goes into two Jani, for each channel separately, but only for the reg part obviously. no Input cap and no output cap necessary as this is all on the unbalancer already. Only very few oarts are left then and you could build a Janus again on a small experiment board.
I guess this will be it. Voltage drop is than only half, so 27mA*1500ohm=40V. As the unbalancer not only reduces ripple, but as well isolates the psu from the swing of the music signal, we have now as well nearly a dual mono psu. The choke will fight a lot of the HF noise which the unbalancer would not be able to fight. the choke inout will be a rectifier saver and has lowest hf-garbage. And still no lytics or big caps needed. The max size will be 47uF of Mundorf Tubecaps (as already today)...and I can play with all kind of rectifiers, even a 274 !!!
Only open question left is if the regulator tube of the Janus needs in any case DC-heater or if AC is sufficient. I have a Janus pcb with and one without the Dc-reg, not sure if the DC heater was only optional for a preamp or if the reg tube already has been DC-heated as well.
First calculation would lead me to a new transformer (i wanted to try your r-core recommendation anyhow, right ?) with 400-0-400V with a resistance of 400ohm to get the right Q of the following filter which would be for 53mA 8H at about 70ohm and a 100uF Mundorf-tubecap as the input for the Jani.
I have still an amorphous core choke double-c with the right specs which is oversized for 200mA, caps are in the current setup already...so need to solder the second board next and order the transformer...and need to figure out if I need Dc-heating for the regtubes...and than this thing should blow me away.
That should be very good at a first look. Let us know how well does it perform
I started to do some more listening before changing the system again....and the tube rectification is a game changer...
I listened to it with the tx2575 as i/v-resistors...and it sounded extremely mellow, soft, nice, but not enough "air", Not less than before, but as the resolution is now improved, you ask for a new level of performance....so, I switched to the Rhopoint ww back, which before I found a bit metallic and annoying...nope...it is absolutely not annoying at all and is polishing the windows you look through....compared to an already pretty high performing tx2575 !!!
It all goes back to what The founder of Linn always stated: Start with the source. I will get the psu of the DAC right now and than revisit my component choices...but the tube rectifiers take a big source of error out of the equation...next will be the choke-input vs. cap-input etc.
Yes, i forgot to say that rhopoint resistors need come more time to break in than z-foil ones. Neohm NOS WWs need some more time yet.
Choke input is surely better than cap input, no doubt about it!
Yau are right, the rhopoint 8G16A needs at least a week 24h of operation to convert from something aweful to something extremely open and neutral...I will have to give my Neoohm upw-50 as well a new chance....
For my experience and imho, fully broken in Rhopoints are slightly better than fully broken in Neohm upw-50s. But your taste could be different, as it's not a neat improvement.
About long break in, anyway, i was talking about Neohm NOS WWs to be used as anode resistors: they really require a long time to sound at their full potential; during that time they sound metallic and overbright, even if much much detailed.
Buy Now RGL0833 from Lintech IS09001:AS9120 Trusted Distributor
...The one type shown in your photo seems to be a croster resistor and a film type actually...have you ever slaughter one and looked into them ? Where did you get them from ?
The other one rgl0879...not even google nows this one...
I purchased them some years ago from an italian guy whose father was a diyer but was dead. The guy was not a diyer so he put on sale some components he found at home, including a pack of mixed values NOS Neohm resistors, probably from the 80s/90s (not many, just 15 or 20). He said the pack had a label stating "Wirewound".
I bought the pack for a bunch of euros as i thought they should be interesting. I was right that time.
I found them very good and i tried to find others on sale, but i had no luck here in EU. I guess a stroke of luck is needed to find any more, or a more serious effort...
Having so few of them, i never thought about breaking one to see what's inside...
Hi guys,
I've just finished my unbalancer which is set as I/V 'current' Dac (4xPCM1704) converter.
I am considering selecting small value (470pF) capacitor for the low pass filters (C5, C6).
What type of capacitor would you recommend in this position (filtering high frequencies): silver mica, C0G, polypropylene, polystyrene. etc?
TIA
bern
TIA
bern
I would go with silva mica or nothing...I am having no filter and perfectly happy...but using an ess9018...but if I remember my own 1704 build i preferred there no filter as well...sounded more natural, even thoigh in theory it should not be audible...
In my setup, removing bass pass filter caps (33khz cut) causes unpleasant HFs rendition, some sibilance and too much presence of some HF instruments (for ex. drum hats or cymbals). Instead, using proper resistors and caps, bass pass filters don't have a negative impact in sound.
But leaving them onboard using high transconductance output tubes (that sound the best) causes slight hum and noises on output.
I'm experimenting with various solutions to fix that: moving filters in another position (before input tubes), introducing output tubes CC grid stoppers, using some output attenuation, etc...
I still can't find a perfect solution, but i'll keep you adviced.
By the way: I made some progress on thetube rectification front...took more time and effort to make it switchable between bridge and fw and change kt so that accepts as well old rectifiers etc.
Result:
- Fullwave (two diodes) sounds extremely musical and nice. The right tone is definetley there. At the same time a bit less dynamic than
- Bridge with two solid state diodes (mur860) and tube rectifier. Sounds a bit like turbo charged. More power, air, dynamics. But at a price. There is a slight mechanical signature, which impresses from a hifi side, but degrades tone, so female voices are a bt artificial in comparison, individual notes of a piano are very pronounced, but the instrument as a whole gets lost a bit etc. It is not huge difference, but notable.
That was with a 30uF input cap and a Mullard gz34. Changed to an 4uF in Oil and plugged in the Psvane 274B we replica. Woooooooowwwwww !! The thing is worth every penny. I was shocked. So detailed, so smooth and liquid. Now I understand those guys in the head-phone forum which praised it so high.
But it changes over time, is in a burn in right now, s need to wait where it will settle down, some reported 400 hours of burn in...
I will change the psu again this weekend to make it switchable between choke and cap input with same b+ coming out of it, have a transformer with 250-0-250 and 350-0-350. Lets see.
I ordered as well a bunch of tv damper diodes like 6ax4 etc, which tomas meyer from vinylsavour likes in his project and will build a complete tube bridge...maybe we can have both: The musicality of the pure tube FW rectification and the dynamics of the hybrid bridge ? That would be a 10/10.
It will be as well interesting to see if cheap damper diodes can be on par with the 274b king of the hill.
Result:
Unfortunately I need low pass filter since I use PCM1704s usually in Pure NOS (NonOverSampling) mode. So without digital filters with standard 44.1kHz content the aliasys and images are close to audio bandwidth. Sometimes I use integer upsampling but I prefer listening to in pure NOS mode.I would go with silva mica or nothing...I am having no filter and perfectly happy...but using an ess9018...but if I remember my own 1704 build i preferred there no filter as well...sounded more natural, even thoigh in theory it should not be audible...
Thanks in advance. I look forward your findings. In the meantime, I will try to experiment with silver mica and NP0/C0G.
I never tested Psvane 274B replica in my system; but i tried Brimar 5Z4GY, that in the same forum is reported to be even better.
I didn't find it any better than my Mullard GZ32, even if they also report it to be ahead of GZ32 instead. No deeper bass, no smoother sound.
But i have an RCA 5R4GY from 1940, that my brother sent me from USA as a gift, and that is slightly better than my GZ32, deeper bass mainly. Somebody says it's on par with real WE 274B for a much lower price... I don't know as i never tested a real WE 274B until now.
I tested other (more recent) 5R4GYs, Brimar included, and i prefer GZ32 overall - but that 1940 babe is a different story.
Mullard's plastic base GZ34 are one SQ level lower than GZ32 IMHO.
Anyway, i'm arguing if the improved SQ you experimented could be partly due to the Oil input cap after the rectifier: that wouldn't sound strange to me. So i'll try one of them as soon as i can and that would be good for my RCA 5R4GY too, as it likes no more than 4uF as first following cap.
What oil cap did you use in that position? It was not bypassed, was it? I heard Mundorf Supreme EVO Oil short cylinders to be very good as filter caps, ever tried them?
- Digital Line Level
- BIII with Broskie Unbalancer vs. EE Minimax Plus - My experience
