For that money you'd build a Linkwitz Pluto. You get fully active speakers, active xo, and amps with that!
Not to mention being designed by one of the best minds in audio reproduction.
PLUTO photos
PLUTO photos
More than a little output limited.For that money you'd build a Linkwitz Pluto.
Here is a killer if you DIY... for less than $1000/pair.
Fostex FE208eZ ~200$/ea
(http://www.madisound.com/catalog/PDF/fostexdrivers/fe208ez.pdf)
plus T-90A ~ 170$/ea
(http://www.madisound.com/catalog/PDF/t90arev.pdf)
here is the cabinet:
https://www.madisound.com/pdf/fostexcabs/208ez_enclrev.pdf
just add cap to each tweeter and L-pad to dial in the tweeter to your taste.
Or this Danish (Jantzen) 2-way... should be with shipping just inside your budget as well..., more budget on crossover and less efficent but still a fine sounding option.
http://www.jantzen-audio.com/download/ja8008-tw034-kit/JA8008_TW034_article_v2_ja_web.pdf
No I haven't.Have you heard the CLS215?
Hmmm, let's see, two 15's, a 6.5" mid and a horn on top. Now where have I seen that before?
Maybe I can find someone who owns a pair and do a side by side.
Fostex FE208eZ ~200$/ea plus T-90A ~ 170$/ea
208ez_enclrev
My experiences with the Fostex factory enclosures has not been good. Supposedly this is one of the better ones.
You would be better off following this path
audio-talk :: View topic - Sachiko Build for Fostex FE208sigma + T90A
dave
Pluto's target output is 115dB. Is this not enough?
And with the money left, subwoofers can be added for true 120db output.
Show me they can actually do that.Pluto's target output is 115dB. Is this not enough?
I ran the numbers in Unibox and you're well shy of 115dB 60Hz up.
Not sure....No I haven't.
What are the drivers and flare?
I made some that looked a bit like that last year as throw togethers with some boxes I had laying around and some spare drivers; JBL2225, 2123, B&C DE250 PT95 WG, DCX and some amps. Very good for 10 mins dial in and not much more assembling them. Boxes were junk and went to a council cleanup a few days later.
It would make an interesting read. Not heard the CLS215 myself, and the few they imported sold fast, thought they'd make good sides/rears for what they were asking for them, about $A700ea IIRC.Maybe I can find someone who owns a pair and do a side by side.
I'd estimate that the Vegas average around 94 db one watt one meter average. The "balanced" poly film tweeters produced rarely exceed 95 db on average, and I doubt the 5 1/4 inch mid did either. Factor in some insertion losses - and 94 db seems about right.
Well, recalling customers I had just like this, my points wereWe HAVE thought about it, and discussed it in these pages, thoroughly, with substantially the opposite conclusion....
a) THIS fellow may really like that "rock and roll" sound and find the Zaphs too smooth...a condition which should un-learn over time, fortunately. Zaphs will definitely sound better.
b) Total SPL might not be enough without a bigger amp.
BUT: so true about the little tweet, I kept thinking these had a horn for some reason. My bad! I suspect the woofer sensitivity is probably bumped up above the tweeters', and therefore maybe a chunk more than the Zaphs still. If he actively biamps the NAD and Sansui, that should fix that problem.
However, if the Zaphs are 12" sealed vs. CVs with 15" ported, maximum displacement is a likely a chunk less. For this application, I'd recommend changing the Zaph to a cabinet with a large, free-flowing port. Since I presume the Cerwins have some crude tube, a big smooth port should close the gap on total output. (I don't know the Zaph 12 parameters, but even if it's more a sealed box design, an undertuned port can almost always be accomodated, extending the low end a bit and relieving some woofer excursion).
Not even close. There's a plot on SL's web-site of Pluto+ ground-plane measurement, although the vertical scale is not aligned so that 0dB = 0dB SPL.
Peter Aczel measures 10% THD at 40Hz when running a frequency sweep such that a measured 85dB SPL is produced 1 meter from the speaker.
The Pluto 2 is equalized to have a 2nd order Butterworth roll-off at 45Hz. Keeping the midrange within its xmax limits you to a program level of 87dB @ 45Hz, about 94dB @ 80Hz, 98dB @ 100Hz, etc.
Mechanical limits are 5dB higher.
Adding sub-woofers with the recommended 100Hz LR4 cross-over bumps you up to 104dB at 100Hz and xmax.
I built the Pluto+ sub-woofers to go with my original Plutos in the second system to get more realistic output levels. The Seas driver allows for nearly 6dB more of headroom than the Peerless (more Sd and xmax) so it'll be better although they still won't be high output speakers.
They're very good (I'd take them over any single driver speaker or conventional 2-way with a dome or ribbon tweeter) but maximum SPL is not a strong point.
At 100Hz. Obviously the equalization is -3dB at 40 Hz.
Reasonable off the shelf speakers
I listened to a pair of Peavey SP-2's on a piano CD yesterday. Sounded decent, but didn't have enough cd material to give a full trial- the shop had mostly rock CD's, not difficult to reproduce. I listened to the SP-5's too, the 2's sounded better on piano bass notes and were $499 ea this week. I got interested because some SP5's showed up on craigslist 100 miles from here, looked to me like old VOT design with a horn on top. Have huge power handling capability and "field re-coneable speakers". Give a pair a listen, I haven't seen anything of that design in a prebuilt unit in years, here in the midwest. Bose & Yamaha is what I am seeing in churches, bleah, all those little 5" speakers chained up in a Bose. I didn't like the Bose 901 when it was the hottest thing in 1973(?). I think the Yamaha speakers people are buying are dedicated PA speakers, don't even pretend to have a top end. Our church is miking the Yamaha piano and playing it from the roof through the Yamaha speakers. Bleah twice.
- best speaker under 1200.00 a pair
