Best 300B SE OPT?
The 7000 series contains 38% Ni.
Btw, didn't see any 7005 in there catalogs....
The am and perm Tamuras are hard to come by even in Japan. Maybe if one is well connected to Japanese DIY cult :D . I expected to come back with plenty of DIY stuff, ended up with none. Just vinyl and raw denim :)
I am all for sound engineering reasons, but we are talking about SET amps where I personally grant more leeway for trying out various things, particularly OPTs.
It's not a free lunch.
Having max 1T with 20Hz swing at full power means copperlosses.
I saw a Tribute finemet transformer on the French Elector forum with 0,55dB copperlosses. Is that the standard nowadays?
Message from Tribute: In other words, we have to take into account the maximum core excitation of these materials, which is 1.56T for amorphous, 1.25T for nanocrystalline and about the same for nickel-iron (depends on nickel content). 80% nickel-iron cores have 0.8T. High quality silicon steel can have over 2T.
A quality OPT will stay under 1T with maximum voltage swing at 20 Herz.
It makes sense to apply Finemet. Over the last 15 years I have gone through the process of winding OPT's with high quality silicon steel, amorphous and nanocrystalline (Finemet).
The good properties of high quality silicon steel (HiB) and nickel-iron in terms of permeability, and the low loss properties of amorphous, are combined in nanocrystalline.
Nanocrystalline is made as an amorphous alloy (same tape thickness of about 22 mu); nanocrystallization gives the material a high permeability, so with nanocrystalline we have a low loss high perm core.
Applying airgaps in single ended OPT's will cost part of permeabilty, but there is enough "left" to make it worthwile. This is confirmed by comparitive inductance measurements of amorphous and Finemet.
Feedback from customers confirm Finemet to be top grade material.
Already some three years ago I replaced amorphous by Finemet; the cores are marginally more expensive but total cost of transformers is dominated by labour anyway so it was a logical move.
Finemet c-cores come in the same dimensions as amorphous c-cores, so with the same coils good comparisons could be made by just exchanging the cores.
actually I don't want to feed the troll, but.....
Tribute: calculating copper loss is part of good transformer design.
Tribute OPT's have maximum 0,3 dB insertion loss; most of them quite a bit less when needed for the application.
It seems that you need another free lecture from smoking-amp ...
Stop spoiling this thread by referring to a French forum without proper evidence.
Most likely "your" 0,55 dB insertion loss was for a line output transformer where this specification is an excellent one.
Copper loss is purely resistive, unless there is excess number of turns and too high value of leakage inductance and stray capacitance, I don't see any problem there.
PS. You are continuously criticize other transformer winders all the way around, what is the purpose of this??? You is not only person left in this world with know-how to design audio transformers.
after 2 weeks with my LL1664AM i have swap it with the normal core to see the effect . and yes the amorphous core is better , the sound is smaller , less definition but i have the sweeter sound that i am used to .
so i will sell the Amorphous transfo and keep the cheapest ones .. :)
amorf power trafos are popular due to very low loss in iron, i am happy to hear what it can mean in audio.
perhaps i my english is not as clear as my amorphous transfo :D
make no mistake the LL1664AM is better everywhere . but it has a color i don"t like or perhaps it"s the color of the iron core that i 'm used too .
the only place where the iron core is better is in the low end power.
i'm pretty sure that the LL1623AM with the better inductance will be perfect for my needs.. with my little experience with OPT i would say that the LL1664 is equal to a hashimoto and better than my James .
Administrator
Joined 2004
When you a/b them, what is the differences?
Treble only effects? Extra details?
These are custom ITs made for me by Monolith Magnetics and cost about 3x what the LL1635:20mA cost to be completely fair. They are also much larger physically speaking, probably twice the size, and bi-filar wound with twice the primary inductance (60H).
I've been a bad boy and not done the measurements I should have so with the exception of being entirely flat at 20Hz compared to -2dB for the old IT consider this all completely anecdotal.
It sounds much cleaner, there is more detail starting quite low, it's: "literally like a veil was lifted." All joking aside it offers a substantial increase in apparent resolution and a reduction in transformer distortion/other artifacts. Imaging also improved which was unexpected.
One of these days I will get around to doing some measurements including FFTs and frequency response at various levels. I imagine this will reveal a rather significant reduction in distortion of all kinds in the output of the driver stage. Other than more extended frequency response this is probably the main benefit of the upgrade.
If nothing else I feel pretty confident in recommending Monolith products, beyond pleased.
:) makes sense, no huge magnetic grains to move
One thing i don´t understand, why so long burn in. From physics view
Until Lundahl, one day, starts to make transformers with four C cores, his current transformers don't deserve to be compared to James. Nor to Hashimoto.
I thought twin bobbin C is better for symmetry, unless yours single bobbin are done with pi winding. Basically same like EI
It's interesting you bring up interstages. Are you finding any drop off in bass response with amorphous core interstages, or does that only apply in the case of OPTs? Would, for instance, an amorphous Lundahl interstage retain all the bass energy that Juanitox is missing in the OPT?
I was not talking about bobbins, windings or core materials. I was talking about *number* of core pieces. As far as I'm aware, all reputable output transformer manufacturers who employ C cores use *four* C cores per one transformer. Lundahl uses *two* C cores per one transformer. He must have his own reasons for doing so. But then, let's compare apples to apples. Or let's compare apples to oranges and say that two C cores match or even outperform four C cores. Logical?
I would be concerned rather about proper "weight" of core used; hopefully lundahl uses right weight of iron, to make opt not bass thin.
One reason i see, is lower manufacturing cost-simplicity, you´re making just one bobbin.
Funny thing, lundahl even makes cores himself from sheet metals bought on drums. Everybody else just buys finshed cores or EIs
