Tolu said:We are writing the year 2008 and these are the manufacturing tolerances of state-of-the-art producers!?
You'll miss them when remaining stocks are gone.
salas said:Kiwame. The pot closes the circuit to ground. [/QUOT
Yes it does, as long as the wiper is in contact with the carbon track
Then I will hoard them and in 20 years I will sell them as NOS parts to ensure my retainment pay!
Skorpio said:salas said:Kiwame. The pot closes the circuit to ground. [/QUOT
We can patch everything up just in case, or we can throw as many components out as we can. If a pot becomes dodgy, noises will not be absorbed as with having a failsafe Rg. In a DIY case there is no face to lose, we replace the pot. I am aware of what Rg is for in B1. I can make final decisions after all else works as wishful thinking likes them to work. First thing is not to get offset in practice. If it will appear in a bad way, some capacitors will appear on the perfboard, and then the parts count and their quality will be overshadowed. I can patch it up as much as that Marv guy's face in Sin City then.
avo7007 said:Anybody knows if the B1 preamp has enough juice to be a good headphone amp too?
Of course not with 32 ohm HP
udailey said:B1 and should be in business .....to drive my drive my ChipAmp and F5 soon
Loved the new chipamp I built so I am sure to fall over when I hear the F5
Hi Udailey,
Have you finished your B1 and tried it with the chipamp? Your veredict?
Antonio
Tolu said:Then I will hoard them and in 20 years I will sell them as NOS parts to ensure my retainment pay!
That's my plan, go find your own.
Hi Choky
Sorry for stealing your idea
I modified B1 power supply (BZLS style; positive side, IRFP240 instead of IRF610), replacing zener stack with 12 x small-green-LED stack.
The output is nicely stabilized at +19.4V
About the sound ...
Running LED-powered B1 with F5, it's huge improvement
* Mid seems to be warmer & sweeter
* High is more relaxed and silky
* Cleaner bass
Listen to a track 3 "High Life" of CD: Jazz at the Pawn Shop Vol.1 is a spooky experience as every instruments got better shape and focus !
Thanks for sharing your experiences
About the sound ...
* Cleaner bass
BURNER said:Hi Choky
Sorry for stealing your idea.............
yup ; I certainly invented that
when you have time - try B1 with split supply ( +/- 9V ) ;
you'll get rid of input cap , and even better supply rejection
Skorpio said:How critical is B1 layout corcerning stability?
Specially input and output wires....could the be close without problems?
no more than any other low gain stage ;
so - keep those wires as much apart you can
Re: Basically what I have done by now
Hi Salas
any listening experience yet?
salas said:Found some spare time, and populated the perf-board. Done half the point to point also. I am putting together 1 positive & 1 negative regulated PSU, 1 output delay relay circuit and 2 channels of capacitor-less B1s. Hopefully in the next few days I will find time to finish it and test it little by little. Will report.
Next post includes the awfully sketched schematic.
Hi Salas
Had work to do and I left this little project behind. I will have to finish the point to point soldering and put it in a small plastic box along with a pot and connect it up so to see about offset behavior and square waves so to adjust resistors and PSU trimmers if needed. Then I will listen. If spare time is found, I will be ready to report everything in a couple of days.
I saw with some interest, that a solution for a active crossover was possible with this simple and hopefully good sounding buffer. For a start I would like to make a active low pass crossover with 12db at 150 Hz.
I just added another B1 and placed R7 + R8 and C4 + C5 between the two B1's.
Is that all? Or are there more into it?
It is 6.8 db down at 150 Hz compared to the -20dB input, so it looks promising.
stigaard123 said:I saw with some interest, that a solution for a active crossover was possible with this simple and hopefully good sounding buffer. For a start I would like to make a active low pass crossover with 12db at 150 Hz.
I think your C4 should be connected to output instead of ground to get it right...
deja vu ?
http://www.diyaudio.com/forums/showthread.php?postid=1555159#post1555159
stigaard123 said:I saw with some interest..........
- B1 Buffer Preamp
