So I'm finaly finished with the dam...
Nice job - glad the front panel arrangement worked for you.
I'm no longer able to control my SK (full version). It was working fine until I managed to mess up the cable from the SK to the display. When I received a replacement (bought on eBay), the display works again, but I no longer have control. The control encoder switches between functions when I turn it (volume to input to filter), but pushing it does nothing - I can't switch inputs or filters or volume. The remote, which was working, now does nothing. The SK is stuck on the coax input, showing unlocked. It still showed unlocked when I hooked up the digital out of my CD player to the coax input.
Any ideas of what could be wrong, and how to get it up and running again?
Thanks!
Thanks!
Thanks for getting back to me, audiozen. The only thing I replaced was the ribbon cable from the main PCB to the display. I had to do that because I had broken some of the connections at the end of the original cable. I replaced it with a cable which was identical to the original, but longer. I'm still using the original display, which is now working fine. I haven't changed anything else.
Could the issue be with the rotary encoder? The connections still seem good, but I'm not sure how to test one of these.
Thanks!
Thanks!
I have broken one of the legs off the infra-red sensor when assembling my DAC project. Can you advise of the supplier part number so I can obtain a replacement.
Thank you.
Here's a link to the current state of my project;
http://www.diyaudio.com/forums/digi...-building-soekris-dam1121-32.html#post5234946
Thank you.
I am very happy with the performance of AZ Oled kit + the Soekris. But I still haven't managed to make a decent enclosure.
Audiozen, you have posted drawings of - what could be a nice a nice enclosure - and I am sure that many of your customers would be interested in buying one. I certainly would. Perhaps you could by do an "interest check" thread to see if there is a sufficient demand?
Where can I buy oled display for this project (od replacement)?
OLED is included in the kits, so you don't need to buy any display else.
The chassis is really a problem. I designed it. But less orders, it is difficult to find suitable processors. And chassis packing and shipping costs are not cheap. I plan to make a sample chassis this month to verify the design. I'll update the progress of the chassis here.
And the balance dual dam1121 setup kits will also be compatible with this chassis.
Please eloborate on balance dual dam1121 setup. It is as Soekris 1121 PDF but with audiozen serial control, you have one fully built?
Like AZ1021S, we now design full featured versions for dual dam1121. Taking into account the users and the cost of dual dam1121 , this setup kits will mainly for own use, a few pieces will be shared.
Display is divided into dot matrix drawing, so you can not replace the display menu or boot picture.
I don't mean the menu or boot image, I mean the data being logged (source, volume, ...). Is there an Arduino (or similar) we can get our hands dirty with?
Thank you again
- Vendor's Bazaar
- AZ OLED setup kits for Soekris dam1021/1121 control
