Aux mixer output to cell phone mic
aux output to microphone input !
Has the phone Actually got a Mic input ? I can see it has a 3.5mm stereo output though. If you want to feed audio directly into the phone, i'm not sure if it can be done. Even if it could, & it was meant for a stereo Mic, you would need more than just a cable. The output from your mixer would be too high, so would require attenuating. Which would most likely you having to make a special lead with attenuating resistors included.
That cable is for Video & stereo Audio ! It has 4 connections, not 3, so no good ayway.
