I use a carbide spiral upcut bit in the center of my jig there, it works beautifully.
Your 2nd order on the subs will be fine but trying to put some kind of a low pass on the NS6 might not be so good.
You'd probably be best off listening to the NS6 before trying to integrate the sub.
If you have the full T&S specsheet on the woofers and the values of the coil & cap I can see about figuring a first order high pass for the NS6's.
I will probably be using my Yamaha receiver, which has a highpass option for my main speakers, so I will just use that.
I havn't figured out what I'm doing for sub amplification yet... I have one of those sure amps thats 4x100w. I'll prolly use that if I can figure out how to hook it up to the receiver...
What size spiral upcut bit? is it a small diameter, like 1/4''? Also, what is a good way to make one of those jigs? I have been using my Regular router (not plunge). My plunge router is fixed to my router table. Should I pick up a seperate plunge router to attach to a jig JUST for circle cuts??
My jig is attached to a fixed base router.
I just use a 1/8" steel pin from Fastenal as my pivot that is long enough for a "plunge" type operation, you just have to make multiple thin passes.
I use a 1/4" spiral upcut bit.
so you don't cut the circle in ONE pass? hhmm maybee thats why my router was spazzing out .............. I'll have to watch some youtube videos lol
On a better note, I have most of the drywall installed in my office. I just have to run some new 12-2 for the outlets under my desk, then build a couple shelves, install my modem/router/phone, build a new desk, paint everything, then install the speakers !
Hello Einric, Looks like a nice project ! What kind of results could one get using a 0.5 Cu ft enclosure ? What size port would be needed ? Also could you post response graphs similar to post 9 ? I'm looking to build something inexpensive for use with a 25 watt amp. Thank-you
