The holes are 0.1" dia with a pitch of 0.190 and 0.330" (diamond pattern), 0.40 thick.
I got that particular material surplus, but will need to buy more. The Metal Supermarkets can order it for you from that place: http://www.diamondman.com/index.html
Peter Daniel said:That assembly slides into 2 x 3" aluminum tubing, the board is attached to the bottom using six 1/4" standoffs. That locks the front plate in position.
2 x 3 ordered.
Have you got diagrams with sizes for the front and rear panels?
sweet found one in my area.
Jeff Vanderweyst
2100 Oxford Street East
London, ON N5V4A4
Phone: (519)659-1212
Fax: (519)659-1213
london@metalsupermarkets.com
http://data.gointranet.com/cgi-bin/unitloc/metal/locator.cgi?cpage=main.html&cu=london&cl=16
thanks
Jeff Vanderweyst
London, ON N5V4A4
Fax: (519)659-1213
thanks
karma said:what grit do you recommend for sanding fresh cut aluminum. to give it that nice smooth finish?
I use 100 on a belt sander.
Studley said:given the increasing interest in computer audio, have you any plans to add a USB (preferably direct USB-12S) input to your NOS DAC?
I surely think about it, and eventually it will be implemented.
i.j.russell said:
2 x 3 ordered.
Peter Daniel said:Yeah, I got the drawings and can email them to you.
if you get a chance may i get a copy?
thanks
However, the DAC in a wooden enclosure sounds better, and even better without any enclosure (that's how I'm using mine).
Yes please. My email is i dot j dot russell at tesco dot net.
I am going to build both enclosures and see which I like best. Unfortunately, domestic arrangements require an enclosure.
- More Vendors...
- Audio Sector
- AudioSector-chip amp kits, dacs, chassis
