Well......., don't have access to my notes, so don't know what the real specs of each are likely to be, but based on published specs it's ~2.47x too large and tuned ~1.42x too high.
If the measured Qts spec is higher and/or it's driven with a high output impedance, then the cab is probably OK and a longer vent will tune it lower if need be.
GM
GM
fwiw, the original Nirvana Super10 sounds good in Greg B's Karlsonator (12)
http://www.diyaudio.com/forums/full-range/239386-karlsonator.html#post3565185
Joined 2009
If anyone has recommendations for a good enclosure for the AN Classic 10 I could use some help. I have seen the plans on the CSA site and they seem pretty plain. Any suggestions would be appreciated. Thanks
I would think some imagination regarding materials and finish is all you need to add to the CSA plans?
......or rearrange the 5.6's dimensions to be a taller MLTL with the driver up to at, or above, an average ear height, so making it 60" high and maintaining the same 18.75" width, then depth = 11.25". Driver down 21.19" from the top and the 6" dia. vent is down 47.56".
All dims overall [o.d.] and assuming a ~0.75"/19 mm panel thickness.
Recommend using a 6" PVC or heavy duty cardboard tube for the vent in case you want to tune the cab lower [longer tube].
GM
GM
