Up for sale are a pair of new Matsushita Tweeters as replacements for the Peerless MT-225 2.25" cone tweeter used in McIntosh loudspeaker models ML-1C, Ml-2C, ML-2M, ML-4C, ML-4M and ML-10C. Made in Japan, and are an improvement over the original Peerless.
These were also used in all the collectible SONAB models, including various Electro-Voice, Dynaco & others.
They are simply a *SUPERB* tweeter any way you slice them. Exceptionally smooth sounding, with an equally exceptional impedance curve (7.6ohms @ 2500hz) with response extending fully to 20khz. 8 Ohm impedance.
I have a few pair, so if you need them for replacements or for a project here you go.
I can't budge on the price, which is fair at $30/pr for a new product. Postage should be very economical.
JBL L-36 Decade Series C$140/pr - Oak Cabinetry
For sale are a pair of JBL L-36 Decade Series 3-way loudspeakers in very good condition. Golden oak cabinetry, cones & dustcaps perfecto. All drivers fully functional. JBL cast logos & covers all present and accounted for (ditto for all cover mounting studs).
CDN$140/pr, local pickup only.
A little more info on the tweeters:
Mounting cutouts are spaced 42mm apart on centre for adjacents and 60mm on centre diametrically. The elongated cutouts are useful for matching up to existing baffle holes (note one of the pictures which shows the Matsushita overlayed on top of the Peerless).
They are a flexible install: meaning, more than one pair can be ganged per loudspeaker increasing output and dispersion. Their physical size allows very close acoustical centre placement to one another.
Another bonus of these tweeters is each has a die-cut, pre-attached airseal.
Hello,
Tried to PM you, but since this is only my first post, I could not. I have a few questions if you still have some left. Will they fit in a cutout for the more modern Peerless cone tweeter (poly)? A couple more questions. pls. My e-mail: mamonlook at yahoo dot com. Thanks!
Ray
Ray
ESS HEIL AMT Tweeter Pair
For sale are a fully functional pair of Alnico drive HEIL AMT tweeters in excellent condition. Ready for installation.
Suitable for use as direct replacement in many ESS / Tempest models or for project use.
Each driver weighs around 3.5lbs
Shipment within North America should be around $20 +/-with no duty payable due to stateside manufacturing.
$95/pr
$95/pr
Ang said:dibs on these!
Bought and (very quickly) paid for... many thanks!
KEF Parts : SP1054 woofers / SP1042 Passives
--------- SP1042 PASSIVES:
Removed from a set of Calindas with consecutive serials.
One pair KEF SP1042 passive radiators, cast baskets.
Aluminum skin over polystyrene cone with butyl rubber suspension, measures 8.25" x 11.75"
Excellent condition, ready for use.
-------- SP1054 WOOFERS:
One pair KEF SP1054 (large magnet structure type) woofers.
8" diameter, bextrene cone with butyl rubber suspension
$150 for both sets (will not seperate).
SONY Esprit Midrange Pair *NICE*
For sale, a fully functioning pair of SONY Esprit Series Midranges. Exc. Cond, ready for use. 2" V.C., large vented magnet structure. Paper cone with a cloth suspension, open cast basket Some superb build quality here. From their Esprit "G" Series line-up
see here:
http://www.audio-heritage.jp/SONY-ESPRIT/speaker/index.html
If you want some real pep in a midrange, here you go.
$55/pr
see here:
$55/pr
- Vendor's Bazaar
- Array's Sales
