Why not? Where did you put your IR sensor? Tbh, my remote didn't arrive yet, so I just did this blindly.You did hall for IR ? It's not necessary to make some window for IR in the wood case.
Sent from my SM-G935F using Tapatalk
Could you please explain how IR remote operates through the wood?
You can try it.
Even though I knew the result, I just tried it to make sure
Wood - dielectric and this is all explanation.
So you are saying that wood is transparent for the spectrum of the infrared light used in remote controls?
It was your achievement
You can propose any version as per your imagination ... but it's work w/o hall.
IR sensor can be placed just behind the front panel w/o hole. Remote work perfect,
I did hole in my first projects but it's not necessary.
Moreover, front panel w/o holes looks more stylish (my own opinion).
IR normally does not pass through the wood. Maybe you have a parasitic passage of reflected beams through some other opening in your construction. Put a remote in completely closed wooden box and see if it works that way.
- Analog Line Level
- Arduino based LDR volume and source selection controller
