anybody tried a LM4780?
I completed my LM4780 amp yesterday. I used one chip for both channels. The schematic was the NI version on the data sheets. Initial listening impressions are very positive. I will need to spend more time with it to compare with the LM3875, but I believe the sound is definitely on par.
Building was pretty straightforward took about 2 hours total. Amp was built p2p. The chip has 5 v- and 5 v+ pins. The v- I bent downward and soldered a wire across all of them. The next level up were the two mute pins. I took one end of a 10k resistor and soldered across both and the other end connected to the v- row below.
The next level of pins (these I didn't move from their original positions) were the v+. Again I soldered a wire across all five. I used 2200uf caps, which were connected to the v- and v+ wires. Next level were the 2 +in and 2 gnd pins. The +in pins had a 1k resistor soldered to them which were connected to the rca's. I'll get back to the grounds in a second.
The last row (bent all the way back to the chip) were the out and -in pins . For each side these had the feedback resistor soldered to them and the gain resistor. The two gain resistors were connected together along with the gnd pins from the previous row. I used this grounding point for all the rca's, speakers, caps and ps. Don't know if its text book, but I'm getting zero hum.
The biggest up sides to this chip are:
1. Two channels one chip.
2. Single -v +v connections and one pair of caps
3. Simple Grounding. Can't possibly mess up.
4. Offset. Stable at below 30mv for both channels
5. Noise. There was no background noise or hum. Where with the same ps I had a little hum with the LM3875
6. My wiring usually looks like a rats nest, but with this chip it was much easier to get a clean layout.
I will post some pictures tonight when I get home...Lee
Here are some pictures of my LM4780
The first picture is the amp sitting on top of the power supply. The heatsink is 6"x6". Ton's of free space inside.
The second picture shows the inside and the third some chip detail. As mentioned before the negative rails are on the bottom. The 10k resistor in the middle is connected to the two mute pins and the neg. rail. Above that you have the positive rail. The two blue resistors are feedback and you can see the gain resistors connected to a central ground point which acts as the star ground for everything in the chasis.
Still doing some listening test, but it is excellent so far...Lee
200Watt Version
li_gangyi said:
hmmm...can we get a bread board layout?? Thanks in advance...they have got so many pins~! and most of them are for power connections...wonder why they need so many??
Bread board is quit possible, just need a lot of patience and carefull attention to SHORT circuits between pins. I did the 200W Bridge/Parallel version. 1st cut off all N/C pins and then joint adjacent same pins eg. 2+4, 8+9, 10+11. Carefully bended all pins to fit in standard breadboard.
Using 40V rails it deliver 180W before clipping start when mounted on a little too small heatsink. Idling temperature is 56deg. C on the IC surface. Bussy with 2nd channel so did not do listening tests.
Some pics.
