Do you know the Audire Audio , shiva tempest, have an Australian distributor.
John Woodhead
Acoustic Concepts
63 Southern Road
Mentone, Victoria 3194 AUSTRALIA
PHONE: 61 3 9585 1622 FAX: 61 3 9585 1244
E-MAIL: info@acousticconcepts.com.au
WEB: <a href=" http://www.acousticconcepts.com.au"> http://www.acousticconcepts.com.au</a>
I called them about 12 months ago and the prices seemed very reasonable, said he got a good deal through quantity and the Aust$ was about 7% higher to the US$ back then. but can't remember the price he quoted
Might be worth an email or phone call ?
James
John Woodhead
Acoustic Concepts
63 Southern Road
James
audiofreak is right...i ran the plots for the Vifa woofers and they didn't fare so well as a sub...rather...they are suited as 'woofers' in a floorstanding speaker.
peerless XLS in a PR box according to someone can produce 116Db. Believe me this driver in a passive radiator box can go very LOUD and LOW. But its too expensive for u anyway, driver+passive radiator costs half a grand.
I can only recommend the Shiva...go buy it now
Is shipping a Blueprint 15" from US to Australia for $140AU ($75US) ripping me off?
Or can shipping be cheaper?
In aus, if the package comes by post and is worth less than $1000 then it should be GST and Customs free ... therefore it will cost ~$570
If however customs decides to take you for a spin the pricing will probably be as follows....
driver = $430
shipping = $140
stupid GST = $60
custom duties = $21.50
total cost ... around $650
driver = $430
shipping = $140
stupid GST = $60
Hey Audiofreak, one last question really, with my amp being so underpowered to cope with this driver, will it cause any damage to the driver and or amp, i have spoken to someone who seems to think it will. Also, what would the problem be if my amp turns out to be 150 watt into 4 ohms instead of 8???? could i still run the driver?
The shiva have dual voice coils. if your amp is 150W into 8 ohms you'll use one voice coil .... if its 150W into 4ohms you'll use both voice coils in parallel... no problem.
Your amp will not cause problems if you keep the volume sensible ... your amp will only cause problems if you push it too hard and it clips continuously which can then kill the driver.
- Any australian who has imported a large and heavy driver from the USA?
