If nothing is burning then you have made some connection error. Check the board for bad soldering. I had case where one resistors pin was not soldered very good
For output transistors i thought to use BD911/912 (3 pairs) because of fake MJ's!
I have made amplifier with those BD's and made some nasty torture for the amp. I have driven it with 18 volts pure sine, which is 40wats for 8 ohm speaker. Nothing burned out. After this i think BD's were originals, fake ones will not survive something like that, i guess
heY !!!! Thanks mate...you are right...
i didnt get time to look at it but you got it pal..
I had blown one od that transistor...and replace it ...i think it must have blown up again ...will have to replace ...
will update as soon as i get the new transitore in.
Thanks again.
Thanks again.
You're welcome!
I had also situation like that some years ago. But, you live, you learn....
Yesterday i was working on my second heat sink for other channel. I have bought some Mospec Mj's but i think they are also fake ones. I don't know how does the original prints look like on Mospec. Well, i just hope that it will work.
Two pairs per channel for some 130 w at 8 ohms will do just fine.
I had also 130w amplifier at 8 ohm with just one pair of fake BD317/318 and it worked very, very nice. It was pupmping the power like blast and did not blew out
Congrats buddy..
Is it working fine with no extra changes and tweaks ???
What speakers are you connectig them on??
Am planning to buy 18 inch 600wat Paudio speakers
http://www.paacoustic.com/Product_Detail.asp?CatalogID=0102&ProductID=C18-650EL
And if it works am planning to make 2 of them and use them with active crossovers..
One for lows and one for mid/high
Testing done
Hey guys testing done...
had some wrongly placed resistors (Value)
Replaced them and am really iimpressed with the quality of sound.
I mean me and friend were expecting some hum or hiss but 0 distortion 0 hum...plays rock on..
But am not happy with the power that its giving me at full level.
I tested it on my ZUNE and Sony erricson phone, its not as loud as i expected....what do you say guys...i need more power...
But AMP desgin is rock solid...
My PCB's are 100% perfect no mistake in the track work at all...
What do you beam by full level?
The amplifier is rated 250w at 4 ohm and about half for 8 ohm.
If you have 8 ohm speaker then the amplifier has something about 125wats.
Do you get distortion at lover level?
Does your preamplifier has enough output to drive the amp at full level?
- Another amp
