This amplifier module named Kelvin is made for testing driver circuit. There is no VI limiter just fast fuses. Work with +/-56V DC PS.
What changes should be done with this circuit to drive o/p transistors like 2sa1943/c5200 or non-darlingtons ?
schematic
utput stage for 'Amplifier Motherboard' work in class E with tracking dawn converter for rail voltages. Rail voltages for outputs is +/-6V DC, and converter increase rail voltage with input signal up to +/-120V DC, and thats mean over 90% efficiency like in class D, but with class AB sound quality.
Power will be 1800W with only 4 pairs of outputs + mosfets for converter.
I will share schematic soon.
hi apexaudio
greetings hope you share schematic of this amp
thanking you
andrew lebon
hi apexaudio
thanking you
andrew lebon
sunfire as mention by ostipper
http://www.diyaudio.com/forums/soli...ower-amplifier-able-alike-mako-shark-eat.html
page 1 post #7
page 1 post #7
hi apexaudio
thanking you
andrew lebon
YAMAHA, CROWN and LAB GRUPEN use similar high efficiency circuits.
apex,
what particular model of crown is this
Xti
Hi Mile could be the tracking down converter can be applied on any amp like b500,step of h900 replace with this tracking down converter?
Yes CROWN do this on xti, same circuits as xls (class AB) or pulse (class H)...
Made for testing, and now this is my favorite home amp. Powerfull, great sound.
HI APEX SIR,
can u share this amp pcb layout in pdf. (top and bottom).
HI APEX SIR,
what is the size of the kelvin amp pcb?
- Amplifier motherboard
