Alpine MRV-1000 repair
That is what I cannot understand. Collector to collector on Q226 to Q224 definitely gives 90V. GND to collector of Q226 gives -20V and GND to Q224 gives 42V. I've quadruple checked this at many different points from the rectifiers all the way to the outputs and the readings are definitely correct. (using both two different meters)
OK, since I've now found out why my voltage readings for anything post transformer was wrong, I need to ascertain whether the channel with correct voltage rails is actually working correctly and why the other channel seems to shut down.
These are the measurements from the channel with "working" rails. (left)
IC801
1. 0.96v
2. 0.96v
3. 3.71v
4. 0.328v
5. 1.58v
6. 5.03v
7. 0.0048v
8. 14.25v
9. 0.16v
10. 0.16v
11. 14.25v
12. 14.25v
13. 5.03v
14. 5.03v
15. 5.03v
16. 0.00v
IC801 - Pin 9
IC801 - Pin 10
Q808 - Drain - all 4 inverters seem to match.
These are the measurements for the right channel which seems to shut down
IC802
1. 0.00v
2. 0.89v
3. 0.08v
4. 0.33v
5. 1.59v
6. 3.81v
7. 0.0047v
8. 14.25v
9. 6.95v
10. 5.40v
11. 14.26v
12. 14.26v
13. 5.03v
14. 5.03v
15. 5.03v
16. 0.00v
IC802 - (Right channel) Pin 9
IC802 - Pin 10
Q809 - Drain - I will check the levels on the others again to be sure but believe they matched. There really is that big an offset.
[/QUOTE]
R842 & R844 are definitely good. Just tested Q815 and gate to drain is essentially short. Drain to source with the bridging wire (G to S) is also short in both directions. I'll assume that the rest of the FET's in that half are also duff too.
I've got some new IRFZ44NPBF's coming in a day or two anyway as I need a full set for my MRV-F400 which is also in the "to be fixed" pile.
