Aleph 30: project completed
Andypairo said:
I still don't see the speaker return.
If connected as adviced it should be OK, but since you said it works fine...
Ciao!
Andrea
I modify the layout with the speaker connection ;)
8,5 Ohm for the resistor it's ok or a I can increase/decrease the value? I use 8,5 because I had available, but i can try with 4, 6 or 10 Ohm if it's better.
thanks for support Andy........ I must offer you a beer ;)
salas said:
Great looking amp. Bravisimo!;) And how do you like the sound? What kind of speakers do you drive?
Thanks salas ;)
I haven't tried the ampli so good because first I want resolve the loop ground.
To date it played about 3 hours with a pair of DIY's speakers with morel component: model York
http://www.audiokit.it/ITAENG/KitDiffusori/2vie/MOREL/York.gif
Very good in my small room :)
Hi Andrea,
the value of the Power Resistor in the Safety Earth to Audio Ground connection is not important.
What is MUCH more important is that it survives longer than the mains fuse if mains were to touch the Audio Ground side.
Most recommend that a pair of Power Diodes wired in inverse parallel be added in parallel to the Power Resistor.
See ESP for a diagram of this.
AndrewT said:
Hi Andrea,
The power resistor is very big
http://www.audiokit.it/ITAENG/Resistenze/100_4555-1.jpg
Should survives mutch that mains fuse for me.
But.......you have an exemple of the circuit with diodes? What is ESP?
Andrea,
I think you may misunderstand the duty that this resistor may have to face if a mains wiring fault or transformer fault develops that connects Live to Audio Ground.
It may have to dissipate P=V^2/8.5ohms ~5.7kW until the fuse blows and the arc extinguishes.
How long will that 10W resistor last trying to dissipate 5.7kW?
I don't know, do you?
How long will a mains fuse last passing ~25A? Look up the tables for your chosen fuse manufacturer and value.
diyAudio Chief Moderator
Joined 2002
You will use 2pieces 5 Ampere diodes, or much bigger, or a diode bridge. One cathode goes to other's anode. This pair you wire in parallel to your 8.5R. So if big current must pass in some failure, it will go through one diode no matter the polarity.
