glass fuses can be very good conductors while blowing. at high currents the metal evaporates creating a highly conductive gas, capable of conducting 100's of amps.
sometime you seen these fuses with the metal on the inner side of the glass tube.
the electronics that had to be protected is definitively destroyed.
sandfilled cedramic fuses avoid the metal from evaporating, and quench a possible sparkover. if the fuse is fed from a mains supply the peak current capacbility can be in the order of 100-1000's of amps. glass fuses can only switch off currents below 40amps
Does anyone knows a soft start module working with the Abletec ALP0400 PS? I would like to control (activate) the soft start by the digital pre (Audiophonics PGA8) and then the ALP0400. A suggestion for a loudspeaker protection board working with the L15D pro amplifier it would be also greatly appreciated.
Many thanks
GiAnt
Many thanks
GiAnt
Soft start
A straight forward solution:
AC 220V-240V 2000W High Power Amplifier Soft Start Switch Delay Protection Kits | eBay
By the way, the item shown in photo 1 at the link you indicated doesn't correspond to subsequent photo (i.e. pcb and components). Probably it is better this
220V-240V AC 2000W High Power Amplifier Soft Starting Switch DIY Kits | eBay
- Class D
- Abletec 53v Dual Rail 450W Supply for $20
