First off, thanks to Papa. He taught me everything I know (still much to learn)
Second, thanks to everyone regarding advice with PCB layout. I definitely learnt a few things (copper pour), as well as picked up some things that needed changing (pad sizes etc). This probably won't be the last iteration of the pcb, but it's a start.
I'll try and get one channel built ASAP
As soon as I have put a square wave through it and confirmed gate resistance values, then I'll post full schematic.Can you share the schematics?
Looks good!!
Maybe just a quick statement of what it is? Did a search on "eSCAPEd" and got a bunch of "escaped" posts. Could do a "goat" search, but I'm guessing all of those posts would be about Bill Buckner.
It's my design so you won't find it anywhere. Actually it's a modified version of one of Papa's amps but all design decisions are mine using his topology. Neary impossible to design something completely original these days. I have many more ideas though which I will be building.
You can thank Star Trek, where I learned everything I know.
Blast from the Past
ECX10N20 and ECX10P20
Exicon Lateral MOSFETS - Our Product Range
I purchase a tube of each from the same manufacturing run.
Really impressed with how good they are matching so far. I've never seen any other devices that have matched this well.
I haven't started measuring the P channel parts yet.
Yeah I think the BUZ and ALFET series made by Semelab are most likely the same.Ah, I think I have seen those exact FETs released by at least three different 'manufacturers' with Exicon being one of them. Will have to dig around to see if I can find the others...
They seem nice enough.
TT electronics Semelab Limited - Magnatec Datasheets
Magnatec. ALFET Lateral MOSFETs
Check these suckers out.
http://products.semelab-tt.com/pdf/magnatec/BUZ900X4.pdf
I might throw these ones at an F6 circuit.
And here is the P channel version.
http://products.semelab-tt.com/pdf/magnatec/BUZ905X4.pdf
I might put an order in for Christmas.
All nice parts from the look of them. I have a bunch of the Semelab, and if
you can put up with the lower transconductance (and in this sandbox you
certainly can) then they all have lots of uses.
Very interesting. The diagram on page 2 suggests each SOT227 device is four MOSFETs in parallel. Guess that makes sense with the 'x4' attached to the end of the part number. Laterals again, I suppose, since they are specified for audio use?
Yep.
- ABFAB Builders Club - building The eSCAPEd Goat Mk I
