S.C. This shows the resistor/cap in parallel connected to PG with a hole at the other end to connect a wire to the metal case.
V10, I'm kinda tire today. Thx for the advice, I'm going to sleep now. Continue tomorrow, our hard working DIYer. GN, sleep well.
http://hk.geocities.com/solomon_choi/GC2.html
A Xfeed Plug that I finished in two days. http://hk.geocities.com/solomon_choi/Xfeed.html
A Question about power supply, should I follow the LM3875 Data sheet's equcation to calculate the Max PS, or just use whatever. However, I don't know how to measure the Max V out of my laptop, MD recorder, and the CD player. Also the Impedance of those sources. The eq from the data sheet http://hk.geocities.com/solomon_choi/GC.html
QQq
S.C. if you are not completely worn out by drawing all those circuit diagrams, I would suggest building the 'standard' GC PSU as shown on my FAQ page .
Go with a 18-0-18 transformer and MUR860 diodes and you won't go far wrong.
And in all the posts that I have read about the GC, I haven't yet seen anybody complain that a device wouldn't work with the GC because of an impedance mismatch.
Re: The final touch
Is it good to have that much copper?
On the previous post, I mean I need two around 35V, but whatever Amp I got.
carlosfm said:Some serious copper.
Re: Re: The final touch
Yes, it is.
Good ground and thick tracks for the PSU pins.
This isn't a preamp...
Yes, it is.
I think I gonna send this
P.S: Man I can never make the picture link right.
Also plz help me out on the other pic which locat under the circuit pics. I don't know how to test those stuff, and Nuuk, your site that wiring tips won't help me. It is because the coloring code of the transfromer isn't the same.
Sorry S.C. I don't think that I can help you on this one. IF you know what you are doing, the only way to find out what those transformers are, is to connect them up and measure them. Even then you may not know what they are rated at.
And it should go without saying that you must know which are the primary leads and which are the secondary leads BEFORE connecting them to a mains supply.
You can look at the wires.
The primary wires are much thinner.
But if you have 3 wires on the primary (115, 230...) and no indication at all, you'll have difficulty in knowing which ones to connect.
- Chip Amps
- A GC Layout check.
