900W H-class PA Amp with Limiter
I created this travo own
I use a silicon steel / crgo as its core
imported from japan
10cm high
3.8 cm thick
7.5 cm diameter circle in
cores weighing 9.5 k
primary wire 1.5 mm
secondary wire 1.8 mm
with turn ratio of 1.5
spent approximately USD 1,000,000 (U.S. $ 90)
and need the time at least for 3 days to finish 1 unit travo
Sorry my english
nice work! may i know where you get your irons? and how much?
Step Driver
Can I use this step driver for B500 with 3 final transistor,Sir??
HX900
hi soerdjanto
greetings have you tested this step driver hows the performance
nice pcb
thanking you
andrew lebon
rung tak jajal kang. rung sempet wektune, nggko nek wes tak jajal, tak kabari yo
I have not tried this layout.
I still constrained by time, so I have not had time to test it
later when I have tried, I would upload pictures
