For first powered amp just do not connect 30V on soft-start circuit.
apex,
150R same arrangement as 330R of soft start when powering up?
for speaker test,100uf if no protect ckt?
Qsc1300
Does any diy'er homebrew the QSC 1300 schematic? anybody please share it with me..
Yes TIP31 is placed on main heatsinkApex...two questions:
1. Protector kit: TR BD241 or TIP31 is placed in heatshink TR final. Is right?
2. Step up driver, can I used dioda RHRP3060 instead MUR1620??
RHRP3060 can be used instead SFA1603, MUR1620 is dual diode.
Yes, 150R is same as two 330R in paralel, 100uF in series with speakers just for listening test for first powered.apex,
You can see soft-start schematic in post #424, use +/-15v (30V) without gnd from protect post #422, and gnd from protect board connect to gnd of PSU board.Thanks Apex...its clear..
One again..please give me schematic softstart for PSU. I see another thread layout PCB and I don't see schematic.
Designing/building an SMPS suitable for this amp is harder than the amp itself.
Let's see here.... +/-110V, capable of 12 amps long term average and 100 amp repetitive bursts (2 channels, 2 ohms). That's not something you can whip together in a weekend (or even a month), nor is it something you're likely to get for free.
You have rightDesigning/building an SMPS suitable for this amp is harder than the amp itself.
Ok , for test at any volume, is DC voltage 0,+/-70V,+/-90V?hi apexaudio
greetings have finally managed to get nsl 32
dc voltages are positive 70 positive 90 0 negative70 negative 90 is it
ok to test amplifier only want to test atlow volume
thanking you
andrew lebon
all voltages from single torriod
Thanks.
Rey
what is the main function of NSL32 LDR, if i remove it coz we cannot find it in any electronic store, does the amp will work fine also?
hello my friends out there, right now left channel of my Konzert K10 is smoking and when i open it found out the are base series resistor of 3.3 ohms, 2watts are open and 4 2SA1943 and 5 2SC5200 is damage...and right now im looking for any who could send me a schematic or service manual of Konzert K10 series.... again thanks to audio machines who send me the service manual of Phonic MAR6... pardz regards dyan kung may service manual ka ng K10 please lang paki send mo naman sa akin....thanks to all of you...
qsc1300
http://www.qscaudio.com/support/library/schems/Discontinued/USA Series/usa1300.pdf
Amp will work fine without NSL32, but then there no clip limiter. You can use some sound procesor with limiter.what is the main function of NSL32 LDR, if i remove it coz we cannot find it in any electronic store, does the amp will work fine also?
- 900W H-class PA Amp with Limiter
