Just received my tubes 8 hours ago and they sound great. I am a little confused about the russian branding though.
In the wikipedia , they show a svetlana tube but it has a rocket logo.
Now in my research thus far, the rocket logo denotes the tube was made in the VOSKHOD factory. Did svetlana go through changes as their brand logo seems to have changed from the S to the winged C.
Either way, the tubes sound great.
PS. I should have read ALL of the wiki...
It has currently found a use as a driver tube in hi-fi tube amplifiers (such as Audio Research models VS55 and VS110) because of its excellent low distortion and low noise characteristics. The tube is being manufactured by "Voshod" plant in Kaluga, Russia (see [1]) and is being distributed in the West under the Sovtek and Svetlana brand names.
Re: Russian
7 and 9 pin miniature Russian tubes have P at the end, i.e. Cyrillic П
Chinese copies omit the letter.
Thanks for the explanation about Chinese J (Military).
Most probably it is taken from American JAN (Joint Army and Navy)
lumeimei said:
no£¬ Russian called 6H1¡Ç
fauxpas said:Did svetlana go through changes as their brand logo seems to have changed from the S to the winged C.
Yes, Svetlana did go through changes, but since 1913 it was Cyrillic "C", but not a Latin "S". The town was renamed from St Petersburg to Leningrad and back, though...
soundbrigade said:Waveman: you forgot Petrograd, the name the city got after the German aggression in 1940. Petersburg was a too much German name....
Do you mean 1914?
In 1940 (before German aggression in 1941) it was Leningrad.
Re: Re: Russian
Like the martial art Jun Fan I guess...
Wavebourn said:Most probably it is taken from American JAN (Joint Army and Navy)
lumeimei said:J (JUN) means:for military use
kathodyne said:...nevertheless it functions quite well in the place of ecc88, if you don't like 'em (matter of taste) just trow in the 6n23p which indeed is the 'real' ecc88.
Having listened to a set of 6N1P tubes I am impressed indeed by these. Is it worth auditioning the 6N23P tubes at all?
This thread comes alive after 3 years... if the topic was done and dusted earlier, hope I get an answer after all this time
This Russian Svetlana 6N1P-EB is the replacement that was being discussed earlier for Chinese 6N1?
Russian 6N1P-EB
For Chinese 6N4 (9 pin) the replacement tube is 12AX7 (any 12AX7 or 12AX7-A)?
I replaced the Chinese EL34s of my amp with EH EL34s, but the sound is too warm. Thinking of changing the pre and rectifier tubes and see if it gets better.
Thanks,
Zia
Russian 6N1P-EB
Thanks,
Zia
I'm wrong - thread sheds light on difference between 12AX7 and 12AX7A.
But still not sure which is the best replacement for the Chinese 6N4 Does the lack of "heater warmup" feature on 12AX7 have any implications in compatibility? I see many makes and models of 12AX7s, while not so many choices for 12AX7A.
I also Got 8X EL34B POWER OUTPUT TUBES on My AMp What ELSE Can I replace it to get a Better Quality BOTTOM ENd Your Help will be Gratefully Appreciated, The AMP has Also Got 5X 6NI TUbES on The Input mode, and I would Like to Replace them with a More Suitable TubeDirect Replacement TUBE. I dont intend to Just Plug The Replacement Tubes Once I get your Answer I will take The AMP to a QUALIFIED Technician to Change The Tubes YOUR HELP will be Appreciated.
Kind Regards
Francis Jansz e. mail fsj@iprimus.com.au
Kind Regards
Francis JANSZ
Your Help will be Welcomed with GRATITUDE.
Kind Regards
Francis JANSZ
e.mail: fsj@iprimus.com.au: Olympic: CURRENT AMP PUSH_PULL MUSIC ANGEL XDSE M9 Mark111
AND THE MUSIC ANGEL has Got 8XC EL34B POWER OUTPUT TUBES , I would Like to Replace them with a More Suitable Replacement Tubes. The Currnt AMp is RATED at 70X70 Watts PER CHANNEL in ULTRA LINEA Mode and 40X40 WATTS PER Channel in CLASS a TRIODE Mode. I am keen to Improve the SOUND without any POWER Loss.I got 5X 6NI Tubes What Direct Replacement TUBE Can I use without any Alterations Thats Safe
Kind Regards
Francis JANSZ
- Tubes / Valves
- 6f2 - 6n1???
