Hi a sample
Hi Meledath !
It would be greatly appreciated if it serves as a reference.
Though it doesn't understand whether to meet the satisfaction
It is an amplifier of about 60W for which my amplifier just used the operational amplifier and MOSFET. Data is not taken whether it is a low swerve. (Because 0.1% or less cannot be measured because there is no enough measurement environment. )
http://www2.plala.or.jp/puthoff/gazou_mk2/amp_WD_MS010_Mk2.GIF
( Now tuning:R21,R22 are 220ohm, C7 is 4.7pF)
This circuit is not so acknowledged, and there seems variously to be opinion.
This is a circuit that uses the current feedback together with the voltage feedback.
Hi Meledath !
some infomations
Hi
Some info about substitution.
I had tested below parts ,and it had to be OK
Q3,Q4,Q5,Q6,Q13,Q14 :2SA1145/2SC2705
Q9,Q10,Q11,Q12 :2SA1015/2SC1815 (but supply VOl MAX +-24V)
I had understood below ,
About Q15,Q16,Q19,Q20 and above Q13,Q14
cob is important,so useing nearly 2.5p(standard)
If to use large cob,I guess it may be need to mend phase compensation and
need to mend R35,R36 to large number about 470ohm-1Kohm.
And may be -3dB point of freq responce must be down.
(now 700KHz 8ohm load at 1W)
Hi
OK!
Hi
OK
So, other info,
Though, I do not know the sound because I have not made this one.
PDF file from OPAmp and MOS FET KIT (I am not parties concerned in the shop. ) of one of JAPAN shop.
It is not 60W......(Postscript)
Kit Top page
http://pure.kyohritsu.com/3110f.html
Manual (at P44 the circuit is here, but size is large)
http://www.technobase.jp/eclib/WPure/MANUAL/wp3110f.pdf
Shop top page
http://eleshop.jp/shop/default.aspx
I think this circuit is not so complex for a beginner.
(Other info)
http://www2s.biglobe.ne.jp/~NAOTO/acs/analog/nonfbamp.htm
http://www7b.biglobe.ne.jp/~kochan/workshop/analog/fetamp.htm
Hi
OK
So, other info,
Kit Top page
Shop top page
(Other info)
no one can suggest local source substitutes if you choose to keep your location secret.the parts are not very common here. can any one prescribe the substitutes?
My vote is for Symasym, sounds great,
http://www.lf-pro.net/mbittner/Sym5_Webpage/symasym5_3.html
best regards
hcbonfim
best regards
hcbonfim
I vote for the symasym topology (sounds even better with a triple OPS) , but the one above deserves investigation/simulation.
It .. (the amp posted by audioholic) is very unique. It seems to be a boosted /ultra bias voltage amp driven by a cascoded balanced input.
I have seen this in preamps ,http://www.triadaudio.net/Triad_Audio/Downloads_files/Ultra%20%20Biasing%20Boost%20with%20Enhanced%20Current%20Mirrors.pdf
but never quite like this (as a power amp).
OS
OS
- 60 w power amplifier
