6 channel amp with 3 TA2020 based amps
If I was to make a unit that had 3 complete un changed TA2020 amps off ebay - say like this one
Lepai TA2020 Class T Amp Mini Stereo Amplifier +Adapter - eBay (item 290407411661 end time Mar-28-10 07:43:34 PDT)
Would I be able to just split the input into 3 channels and feed it to each ?
Of course power supply - I can split that. 12-18V and say 6+ amps.
But will the input signal degrade too much if I split it 3 X.
Then if I build a tube buffer like a 12AU7, would it be 1 for the whole thing in front of all the splitting, or do I have to put one per channel ?
Thanks in advance guys.
Cool.
Srinath.
Oh, the kenwood I have and am using now to run the 1 chip amp I got I am running it out of the headphone jack since it has volume control. Now that output can be split ?
Also how much distortion is sent out of the preamp side of the receiver ?
Thanks in advance.
Cool.
Srinath.
