I'm a bit rusty - can I use the Micro Commercial Co MPSA92-AP as a replacement for the 512-MPSA92 in the MOX op amp (http://www.diyaudio.com/forums/analog-line-level/27651-mox-active-crossover.html The only spec difference between the two is that at 10 mAdc the MPSA92-AP has an Hfe of 80 where the 512-MPSA92 is 40.
512-MPSA92 http://www.mouser.com/ds/2/149/MPSA92-195894.pdf
MPSA92-AP http://www.mccsemi.com/up_pdf/MPSA92(TO-92).pdf
page not found......................... the MOX op amp (http://www.diyaudio.com/forums/analog-line-level/27651-mox-active-crossover.html .......................
This was posted just 4days ago.
Why is it lost now?
The link should be:
Try the links now. A bracket and question mark had been added at the end of each corrupting them. Easily done when you copy and paste and don't notice other text on the line has been added
Thanks - sorry for my error.
