512-MPSA92 Replacement in MOX
I'm a bit rusty - can I use the Micro Commercial Co MPSA92-AP as a replacement for the 512-MPSA92 in the MOX op amp (http://www.diyaudio.com/forums/analog-line-level/27651-mox-active-crossover.html The only spec difference between the two is that at 10 mAdc the MPSA92-AP has an Hfe of 80 where the 512-MPSA92 is 40.
512-MPSA92 http://www.mouser.com/ds/2/149/MPSA92-195894.pdf
MPSA92-AP http://www.mccsemi.com/up_pdf/MPSA92(TO-92).pdf
