500W PA amplifier with Limiter
that was a nice exlpanation andrew. i was hoping to make a microcontroller controlled protect circuit from apex circuit. so far apex give me informations how the circuit work. my main concern is, does the microcontroller make a noise interference to the amplifier? it would run at 4mhz internal oscillator.
Diyers don't like protections. I think quad OP with several transistors is already to much for diyers. This amplifier with OP amp in input stage also not popular like 'school book' amps.
Add step driver with TL072 to B500, you can use PSU from H900, and you get class H amp with same power as H900.
thanks to this crown design step driver
even IR2117 is not available here
i can still pursue my first CLASS H
see old casing prepared for new class h amp almost only 5'' in height
that was an old amp and casing
^^ ohh you want to add 2x40 and 2x18 to the existing traffo :=) thats fine.
hello mate,
please check this one,is Ou1 rated400v in the center the blue one,
is this fine(400v)?
and i used bc547b,instead of 546,
is this fine also?
thats what i have in stock.
and the BF 422/423 their replacement is MPSA92/93 but when i purchase MPSA the marking is diff. it is ksp92 &ksp93
is this fine?
hello mate,
here it is TLO72
Component layout have mistake 47pF is notification as 0u1. ZF10 and 10uF on negative side wrong direction, sorry.
BF422/BF423 can be replaced with MPSA42/MPSA92, but different pin layout.
thank you apex,
47pf
i was thinking all caps noted in 47 is in nf,so it was also my mistake,
should i have to change them?47pf(682) is not same as 47nf(473)
i was about to enjoy my new true rms 177,cheking caps in nf from old pcb's from pc monitor and fit it to tlo step driver,sadly pf is out of it's reach
thank you apex,
47pf
You can see all component values on step driver schematic.
47 is 47pF
682 is 6,8nF
473 is 47nF
