500W PA amplifier with Limiter
With another Apex user i found this problem too. So, this not a big deal problem for me. I just remove the RC from zobel network. I dont know what effected cause while i remove it. But this what i need to prevent damage if i forget to connect my load.
Can you post the shematic you followed using darlington.... Also posting some pictures of your work would make some friends easier to help.
Ooо, a major component of the amplifier.:)
I wanted to ask Mr.Mile or the other could answer, even fellow DIYer may experience the same thing with this problem, .. why the H900 standard when playing a kick drum, bass disappears (PA as SUB) ... the 4R or 8R load. but if for a bass guitar no problem, voltage regulator 45ac-90ac-ct ... 4kva. and I do not use nsl 32. where is that must be repaired or is there any other damage?
sorry my bad english
thanks and regards
i think because of your box speaker design. Prevent a 90 degre of all your corner inside your box. Its to prevent canceling.
