Re: A CTRL PrtScn
Note the seemingly fixed 'con' (conic), 'Exp' (exponential), etc. descriptions next to the left of the 'horn' segment length boxes......these can be double clicked and/or highlighted and changed to other flare types, so change any 'line' of 'horn' segments with values to 'con' and you can then input the desired segment length in the box to its right.
Note too that you need to re-input all the driver data and the 'horn' Vrc, etc. data below it. Once all data is the same as mine, click calc and view the various plots and you should wind up with this design.
This is all in the HELP files BTW.
GM
mikee55 said:Different to yours too.
GM
Okay, got that.
Hello GM,
Thankyou for taking some time to help. I've now got Hornresp the same as yours.
I've had acouple of sunny days and today grey, rainy and a lot of Wind.
Batteries on my wireless mouse died earlier, , it just stopped dead. I used Enigiser Alkalines, stuck em in my charger for a few hours and they seem to have charged up
Okay, don't know what all those numbers mean, but even the schematic matches yours.
Thank you
Hello GM,
Thank you
Greets!
You're welcome!
Considering your being in England, the weather conjures up memories of Wuthering Heights' bleak gray/black-and-white outdoor scenes.
The HELP files explains all.
FWIW, here's your driver in the T/S max flat alignment I used to compare the programs with:
GM
You're welcome!
GM
More like Red in England
As in Debt.
Anyways, hi again. I went through the help files and couldn't make much sense. I think Vrc is the size of one chamber, not sure about the other, or do I find that by taking Vrc away from the System Volume?
Being as its 5 past midnight, I have to sleep now, got to get the kids ready for school early. Hopefully I can figure out and learn more tommorrow????
Mikee55
As in Debt.
Mikee55
