3886inv gainclone PCB,group buy
for paulb
Thanks digi. Will you confirm the total price, or should I add it up myself?
14 LM3886s at $4US
4 BLDs at $3US
Shipping at $6US
Is this correct?
Correct:)You can calculate by yourself too,then confirm through the mail.shipping cost is sharing,$6 to anywhere by air.
for Aunkst
Will you be posting when the shipments go out? I am looking forward to starting a new amp.
All the orders will send out on Nov25.(Approximate)
I will accept orders till Nov 15,and then fall to making.the process should take 7-10days.
for roibm,
you are welcomed:)its right.
Looks like
the Diode holes are a bit wide set for the OnSemi MUR860s. Not really a problem as the MUR860 legs can be bent accordingly. But it might be a good change to make it a straight fit if you were reving the board at some point.
If someone was using "regular" diodes they could always mount them a bit vertical if the hole spacing was narrower.
Nice boards though! Mine are coming along.
