Older thread....not sure if you decided but I'd add that I'd go the dual 10" route to avoid floor bounce which would be forced if using a single bass driver given how close it needs to be to the Fullrange.
There's not a lot of pro 10's that dig deep.....they're mostly midbass units. That being said, there's plenty of hifi 10's that will dig deep and as a pair will provide some added efficiency. Scanspeak Discovery 26w in a series pair would be my choice in 2.75cuft ported.
Ok decided, I want the Beyma 10BR60. I have a Rotel RMB 1048 with 8x40w of power amp flying to me soon.
Now I just need a great cabinet design...These will be actively crossed, and using the MiniDSP will have control so can adjust on the fly.
I want the cabinet to be curved, with a small width baffle as possible. That is all I require.
Any ideas for ported designs, or sealed, push/pull, push/push etc...?
Well, still haven't purchased.
Been looking at having OB woofers, especially to mate with my Betsy's that are sat around.
Any reason not to try a Eminence Alpha 15a each side, running OB as a FAST, helper woofer?
These are still to be mated to Alpair 7.3 for 100Hz or so up. And to be tried out with the Betsy.
- Full Range
- 2x10 or 1x12" UK Woofer suggestions please.
