with le of 1,6 its looks ok in the 466 post cab.
466 post cab was my first pick.
im not good in calculating ,with compression figures ect
but a sine wave @42 hz reach x-var @ 500 watts (no compression calculated.
since music is never a sine wave you could probably put 1000wats trough it whit no problems,i think even more.
th are known to give low excursion
here is the sym with the corrected le
looks nice.
Can you squeeze out any more db out of the tbx sim
the sim is the box from post 466
i can squeeze more but it wil get bigger and bigger.
remember the box 466 is already 575 ltrs netto volume.
with handels and casters just moveable with one person
I wish I could get a little more db out of it, but if it is going to be too huge it does not make sense
Just order the speakers
looks nice.
Let's stick with this
ok ill see if i get it finished this weekend.
this box is to big for printing on paper.
i can make al smaller pannels printable.
when you cut the side pannels you can draw it on.
btw the pannels you use are 48" wide without tongue and groove?
so we make the box exactly 48"high ?
Ok 48" high is not bad at all
The speakers should arrive by then
do the pannels you use have tongue and groove?
I never use tongue and groove before don't you need a router to make tongue and grove. guess I have to learn
let me explain
if the pannels you use hav tongeu and groove,then it must be cut off,then you no longer have 48"availeble.
if they are 48" without , we can use all 48".
im already on it see
Ok now I understand what your saying.
its just an opening ,the mouth
you can make it any form, round square hexagon,as long as its area is between 2200 and 2700 cm2
i simmed 2500cm2 .
you can sim it and change it to see what size you prefer.
going to bed now ,the alarm go's of at 6 am ...
Ok epa
- Subwoofers
- 18TBX100 vs 2lab12
