I have a bunch of 1624 I haven't used, and when considering a 2a3 PP amp I wondered about 1624 in triode instead. Information I have so far is:
- 2.5v filaments at 2A. about 2K Rp in triode, mu about 8-10 (??)
- Operating points are like 1619 or 6V6, not 807 as often suggested.
- Max plate dissipation looks like 15 to 16W, not more.
- Can't find triode curves, so presumably 6V6 in triode is closest?
- Steve Bench reports good results with starved filament
- Can be used as low voltage driver (HT about 200v)
- Some users report microphonics, and also loose plate top caps
- Not sure what value grid leak to use - maybe lower?
- Sound reported as warm and smooth but that's anecdotal
- Probably needs 8K A-A OPT in PP. Maybe 6.6K?
Has anyone any experience of this in triode, and any other information, curves, operating points, OPT values, applications etc?
Andy
Andy
I looked at a 1624 closely and the insides look identical to a 807. It's hard to believe it isn't a directly heated version of a 807. The datasheet says 25W dissipation which is the same as the 807. On the other hand the datasheet says "see 1619 curves", and that has a dissipation of 15W. Bit confusing eh!
andy
andy
Also look at Gary Pimm's Tabor design.
1624 PP.
Gary brought this amp to the Triode Festival in Germany years ago.
I remembered it to sound fresh and open, not "warm" in traditional valve terms.
It is not trioded though.
Need some 1624's? I have some 160 NOS RCA's in the attic.
1624 PP.
Hello Pieter!
I'm only really interested in triodes, but I take your point about the Tabor. I have 25 tubes myself. Enough not to worry about output tubes for some time!!
Have you tried it in triode, and what did you find? It's also a useful driver I imagine since it has decent gain of around 10. It was originally used in 200W transmitters to drive 813s.
Andy
Andy
Frank's has data sheets for this type.
It doesn't look like the 1624 would do well as a pseudotriode, as it seems to have been designed mainly for Class *2 operation, and doesn't pull very much current with Vgk= 0V. The spec sheet also implies Class *2 operation in requiring that the grid drivers have a Zo= 500R or less.
Easily managed with MOSFET source follower grid drivers. You should get ~70W of audio from a PP pair. Probably best to use 'em that way.
The 1624 is the glass version of the 1619 -- a metal tube. Higher Pd (metal tubes get very hot) and same shape and size as an 807, but definitely not a "DH 807", as the characteristics are quite different.
As a triode 1624 has Ra 2.5k mu 10 so it's like a beefed-up 6V6 . Good for a watt or so SE with 8k output transformer . Two in parallel would be more interesting and could use a 3.5k-4k output transformer but very inefficient , a single 2A3 would do better . Ultra linear probably a better application for this valve .
316A
316A
Andy, I absolutely see what you want to point out. And honestly, you're right about that. I don't want to badmouth everything from the very first. But a bit of rationality will keep you away from disappointment.
I have a bunch of 1625 and started with a SE in triode connection. I was absolutely unsatisfied with the output power and first thought something else was wrong. But no...you only get a bit over 1W. Yepp...a single watt from a 25W triode. The output power tenfolded when connected as pentode. I liked the increased dynamic range due to the power reserve much more than the triode sound.
The extremely good STC datasheet shows nearly all topologies with that tube: www.tubezone.net/pdf/807stc.pdf
So, no triode bashing from my side, just don't be suprised when the triode power of your 1624 won't be sufficient.
316A
The best application (other than as a Class B or Class C RF amp) is PP, pentode. That's what it was designed to do. If it requires any help, then you can always add local NFB and/or gNFB to take off however much "edge" these produce as PP audio finals.
Getting a watt or two from a tube rated for Pd= 25W that'll have to run at Vpp= 600V is absurd. You'd be better off sticking with actual audio triodes (45, 2A3, 6A3) or vertical deflection triodes. If you're not a "sand-o-phobe", then RF power triodes also become a possibility. The horizontal deflection pents wired as pseudotriodes would also be much better.
If you just have to do it, and can live with the results, well, there have been crazier things done.
Miles - there is indeed a bit of an ominous silence about using the 1624 in triode. Mountains of them about and if it really were a directly heated 807 then surely somebody would have published a few schematics. But they haven't. Mind, nobody used the 2E22 much and that was a much better choice in triode.
It's looking more like a driver in triode if it's anything. I was debating whether to go on with trying this or using 2a3/6B4G outputs exactly like you say, and frankly it's looking like the 2a3s unless anybody has some bright ideas. I'm still curious to lash up something and have a listen, but motivation is getting a bit rocky!!
Andy
Andy
Wait and second,
I thought the 1625 was the equivalent to the 807 besides the 6v verses 12v???
I have not researched the 1624. But my amps are based on the specs of the 1625 tube.
Am I missing something?
Here are the specs for the 1624 and nowhere does it say refer to the 807 for specs?
NJ7P Tube Database Search
Now if you look at the 1625 it will refer you to the 807 specs.
Scott
Scott
how many RAC 1624 do you have now?
hi:
how many RCA 1624 doyou have now? are they all new in original box?
how much are they? if Tthe price good ,I want to buy all of them ,please contact me :yangmei191@hotmail.com
Andy
hi:
- Tubes / Valves
- 1624 as DHT triode outputs
