I have built the preamp Apex A2 with NE5532. Sounds great, is easy to build and cheap. Super as a pre-amplifier for meters, small amps, test purposes ...
It may be that someone finds it useful.
Unfortunately, there are many different potentometers footprints and so I for myself had not the right one on the shelf. So be careful
regards Olaf
Is this the non-inverting LinearPre?
No, this is inverting Linear Pre and since it is inverting it sounds different than non-inverting. Warmer and softer, somewhat less detailed and bright than non-inverting. Many people find it more musical than non-inverting.
Are you sure ?
You can get an inverted signal just by reversing the speaker leads and that doesn't sound any different from the right way unless you use non musical test signals.
Look here: A Directory of Apex Audio Amplifiersand here:A Directory of Apex Audio Amplifiers - Chapter 2
But the real stuff you will only find in the thread. It's magic
regards Olaf
regards Olaf
Here you go.
regards Olaf
that actually helped a lot, thank you
You should read the thread... You should read the M. Mile Post #9746How much power is the APEX NX12 amplifier with 60-0-60V power, and how much should I install BIAS in this amplifier?
- 100W Ultimate Fidelity Amplifier
