100W Ultimate Fidelity Amplifier
@wiljj78 can you please post gerber files for this AX11 layout ?
regards,
hello sit that is actually a change I did to the file myself from mister Willy I do have the files gerbers and Sprint file if want too I'll attached them here :)
  • AX-11 mod.zip
On the PCB with the wires (first image) the MPSA92 is reversed and all the 2N5551 are correct.
On the other PCB (second image) The MPSA92 is correct but all the 2n5551 are inverted.
Are you sure that the two diodes above the capacitor of 47uF are indeed 1N4148 because I find them big!
1. i test it in different condithion
2. i assembled mpsa92 like the pcb and 2n5551 in reversed the pcb file and all is correct.
3. yes. that is 4148
i do not undrestand what is the problem. 2sc5200 and irf540 and irf9540 after 1 second is very hot wen i conected power to the board.
Hello everyone
For fun I drew a layout of the AX11 amplifier based on the miniamp with some small modifications to facilitate setting up on the heatsink.
I checked the connections and there is no error but I do not know yet if I will make this amplifier.
If the gerber or .lay6 files are of interest to someone, I will make them available.
Hello everyone
Finally I will make this amplifier. I received the PCBs but I forgot to give a color for the Silkscreen. :D
Regard's
