100W Ultimate Fidelity Amplifier
Apex,
I reflowed all tracks and did some measurements and this is what i came with. i also replace bias resistor just in case it was defective but it was good. all this measurements are with no load, inputs shorted.
I inputted your rail voltages into my spice file and here are the voltages you should see.
  • AX14 voltages.pdf
Greetings mr.apex sir its my apex ax11 good bass and crispy sound thank you sir
the schematic i posted was from the first post but the placement on the PCB is correct. Replaced R20, R21 and Q11, same outcome. did diode test on q11 after removed and it seems good. I will apreciate all the help.
first remove the 104 cap and direct short the sgnd with psu gnd and then measure .if you make own pcb then pcb is faulty and if you made on thread pcb then any component and polarity issue.
