PCB from latest SSR protect schematic.
Please check
Sprint layout file attached
Nice pcb, only replace 15k with 4k7 in DC detect circuit.
I was wrong. I etched the wrong ones. Too many downloads.I etched a new pair. I will catch the 4k7 when I populate.
Blessings, Terry
Protect with transistors DC detect is ok, it work with about +2 and -9V DC voltage. DC detect with triac work with +/-2V.
As soon as someone built a prototype and has all the resistor values I plant to build it to.
I need a couple of them. I really do not like the relay type because it need a high quality relay to not to degrade the sound to much.
Thank you Mile sharing with us!!!
Greetings
Greetings
The circuit actually works with the changes suggested in post #5579. It will trip instantly with +1v5dc on the output. I tested another dc protect unit that I have and it works the same way. +1v5 and -6V to trip. Probably not an issue as 6v won't hurt a speaker.As soon as someone built a prototype and has all the resistor values I plant to build it to.
Greetings
We thank you for the attached file!PCB from latest SSR protect schematic.
Please check
![nod :nod: :nod:](https://files.diyaudio.com/forums/images/smilies/nod.gif)
hi
i am working on apex 11. i could not get the correct response , i am getting the poor bass response and getting the high hf response. ie i am getting 19 volts at 100 hz and 55 volts at 10k.
i have given 30 volts at low rail and 60 volts at high rail voltage.
please help me to correct my errors
hi
You work on HX11, can you post pictures?
Please check
Thanks for the file Mr. C08bm. I will update my layout based on your layout.
Prasi
Thank you for your reply sir.
i have used mje350 and mje340 as a pre driver instead of 2sa1407 and 2sc3601.
In schematic there is only one MPSA92 but there are two MPSA92 in your version.
Look at layout done by willy.
Sonal Kunal
Can you post pictures of your amp?
This file is from a relay protection,can you upload the right file?PCB from latest SSR protect schematic.
Please check
Thanks.
Thanks.
there is another sheet on the bottom that has the SSR layout.
reg
Prasi
Thans prasi, i see this now.Hi,
reg
Prasi
- 100W Ultimate Fidelity Amplifier
