COOOLL!For freinds may interested of SANKEN version.
Thank's!
wiljj can u share green masking layout also so I can make good looking pcb
Hello Shravanth,
Can you check post # 2079??
yup.. wiljj I saw post #2079 there is art work and silk screen but there is no green making layout
trying make pcb like this- http://www.google.co.in/imgres?q=pc...bnw=335&start=20&ndsp=12&tx=155.375&ty=60.875
trying make pcb like this- Google Image Result for http://www.dragonflyalley.com/images/YUanimator/YUSA-11-pcbBackB.jpg
You mean this one??
hai olafk I have just brought all components , tommarow I am going to make pcb
ok, I'm really curious.
ya. . . . but only yellow pads should be there
Maybe this can help.
thanks wiljj . . . thnk u very much that's what I need in two days I will upload my pcbs
AX11 look very nice with SANKEN, thanks.
My TO3 version of AX11 for more power.
Used BD679A instead of MPSA13
MJE15030/15031 instead of BD139/140
MJE340/350 instead of BC639/640
MJ15003/15004 instead of BD249/250
Also you need 2N5551 or 2sc2240 instead of BC546, if you use higher voltage.
Part list:
1. MJ15003 – 1 pc.
2. MJ15004 – 1 pc.
3. MJE15030 – 1 pc.
4. MJE15031 – 1 pc.
5. MJE340– 1 pc.
6. MJE350 – 1 pc.
7. BD679A – 1 pc.
8. MPSA92 ( replacements 2N5401,BF421,2N5416) – 1 pc.
9. BC546 ( replacements 2N5551) – 3 pcs.
1. R22/5W – 2 pcs.
2. 220R – 2 pc.
3. 10R – 2 pcs.
4. 100R – 2 pcs.
5. 4K7 – 1 pc.
6. 3K3 – 1 pc.
7. 680R – 4 pcs.
8. 22K – 3 pcs.
9. 2K2 – 2 pcs.
10. 4R7/1W – 1 pc.
1. 47uf/63V – 2 pcs.
2. 100uf/50V – 1 pc.
3. 10uf/25V – 1 pc.
4. 330pf/63V – 3 pcs.
5. 100nf/63V – 3 pcs.
1. 1N4148 – 3 pcs.
PCB dimensions 94x90mm
1. MJ15003 – 1 pc.
2. MJ15004 – 1 pc.
3. MJE15030 – 1 pc.
4. MJE15031 – 1 pc.
5. MJE340– 1 pc.
6. MJE350 – 1 pc.
7. BD679A – 1 pc.
1. R22/5W – 2 pcs.
2. 220R – 2 pc.
3. 10R – 2 pcs.
4. 100R – 2 pcs.
5. 4K7 – 1 pc.
6. 3K3 – 1 pc.
7. 680R – 4 pcs.
8. 22K – 3 pcs.
9. 2K2 – 2 pcs.
10. 4R7/1W – 1 pc.
3. 10uf/25V – 1 pc.
1. 1N4148 – 3 pcs.
You're most welcome Mr. Mile...
- 100W Ultimate Fidelity Amplifier
