Can we use different parts like 15023 at output. 0281-0302 are hard to find Sir.
TIP35C/36C can be use for step and MJW21195/21196 for outputs.
BA2000....Looks like Proline T-Amp.
Many brands use this simple realable circuit for high power PA amplifiers.
hi apex audio i want soft start circuit pcb layout file which i didn't find. you are doing a great job.love you.
I share many soft-start circuits.
Why did you avoid the rail switching?
Sajti
I have some 2x90vac transformers and B2000 was made only for use them, but with series connect of outputs TIP35C/36C can be use with +/-90V rail or MJ15003/15004 with +/-120V...
I guess, that transformers are huge... This amp need about 3kVA...
Sajti
Sajti
Transformers are for 4U case.
That will be nice project.
I think the class TD would be better for that high voltage.
Sajti
It is written 5xMPSA42/92 next to your red circle.
having multiple accounts is not allowed under the diyaudio rules. http://www.diyaudio.com/forums/site-announcements/167561-diyaudio-rules.html
As the Driex account is new and still under moderation it will be deleted. If this is repeated you will be banned.
- 1000W Simple PA Amplifier
