You have to do a lot of research, then take a leap of faith. Even if someone else has used the driver and says yay or nay, does that mean in your application it won't be correct. Case in point: BMS. I think they're superb, but you don't like them. Who's correct? Neither, just different opinion.angeloitacare said:i have no experience with these woofers for home use.
Agonise less, build more. You make beautiful speakers.
beyma x 18 sound
there are two woofers, which i am looking closer
a 18sound :
http://www.eighteensound.it/index.aspx?mainMenu=view_product&pid=257
and
http://www.toutlehautparleur.com/basse-frequence/beyma-112ndw-p-304.html
i am thinking to make a line array of 3 or 4 woofers each side.
the 18sound seems to have many advanced features.
any opinions ?
a 18sound :
and
any opinions ?
Like no bass and plenty of the midbass
You would be better off with the Beyma Studio 12B100/R ... revised version with rubber surrround ... and at least get some of the low bass
But it needs a bigger box/BR ... 75/100 liter ... F3, 40/36hz
Or you might get away with smaller closed with some EQ
