10" driver for Bass tower in Horn project
angeloitacare said:
i have no experience with these woofers for home use.
You have to do a lot of research, then take a leap of faith. Even if someone else has used the driver and says yay or nay, does that mean in your application it won't be correct. Case in point: BMS. I think they're superb, but you don't like them. Who's correct? Neither, just different opinion.
Agonise less, build more. You make beautiful speakers.
Ex-Moderator R.I.P.
Joined 2005
Like no bass and plenty of the midbass
You would be better off with the Beyma Studio 12B100/R ... revised version with rubber surrround ... and at least get some of the low bass
But it needs a bigger box/BR ... 75/100 liter ... F3, 40/36hz
Or you might get away with smaller closed with some EQ
