Salas DCG3 preamp (line & headphone)
Proof :D
Reactions: 1 users
diyAudio Chief Moderator
Joined 2002
Remove them carefully and reverse them. Don't dwell long with the iron. Help rework with solder wick if you got, they are sensitive. Unless you got some spares. While you are at it inspect both sides for dirt, flux crud, solder bridges, missed joints, dull joints, suspect strength joints, weak pins etc. Canned air, brushes, Kimwipes, Isopropyl Alcohol (IPA) are your friends.
If yours is a single input only configuration, just continue from RCA barrel pin through signal wiring to pot pin "C" to ground point "G" line-in DCG3 terminal.
*If when touching the volume knob you will get some buzz then run a thin wire from a point C and jam it between the mounting nut for the bracket and the pot.
Does it mean I connect the Left barrel pin to one pole of the potentiometer on C, and the right barrel pin to another pin of C on the potentiometer? And then connect the respective right and left inputs to the pre?
