With this solution, the control of the speaker by the amplifier will be reduced by at least half.You will get 4 ohms by forming two series of 2 drivers each, and then parallel them.
Thanks for your speedy replies guys, much appreciated I'm aware 2 tpa's in pbtl would do the job but just wondered if anything like this has been tried before. Was thinking of using the tpa outputs to drive a pair of Automotive N- and P-Channel 40 V (D-S) 175 °C MOSFETs.
For example, to open the N channel half, you need to apply a voltage to G that is 10V greater than the voltage to S. How are you going to do this using the TPA output?
Was thinking of driving a P-N pair like below or would this mess up things like dead time ?
The keys will burn out if the supply voltage is more than 20V. There will also be an unacceptable through current through the power switches, since the switches will be open simultaneously when switching the control voltage.Was thinking of using a P-N pair like below :
Most 4-channel TPA amplifiers are already bridged, which gives 2 BTL channels.Always Was reading not to use bridged class D amps
I think his amp is designed in mono PBTL. The TI doc documents all the ways to use the output stage.
the amp has 2 3116's one in stereo one for the sub, so the sub amp must be bridged as it has only one output. driving a 1 ohm load puts .5 ohm on each channel of the one 3116 that drives the sub. playing music on the edge of going into protection it gets hot but not as hot as other amps i have. makes no sense how it works so good. i havent turned it off in 5 years either. passive cooling too.
Really I am quite impressed by the sound quality of these small class D amps.
I tested the whuzi audio ones and it's so good enough that I do not think about something better.
https://www.diyaudio.com/community/threads/unboxing-zk-mt21-tpa3116.403857/#post-7518041
https://www.diyaudio.com/community/threads/difference-between-cs8673-and-tpa3116.405281/
https://www.diyaudio.com/community/threads/unboxing-zk-502mt-cs8673e.410107/#post-7623495
Its interesting that they survive at 1 ohm yet .5 ohms.
Im not sure what the benefit is though
1 ohm load is the worst load possible for any amp.
Easier to get voltage not waste so much heat in current.
Distortion be high at 4 ohms yet 2 then 1
ouch
4 ohms loads bother me
anything below it makes me cringe.
point is just build a amp with more voltage
swing
ouch
swing
MIne is the 12" T5.122 it has dual 2 ohm vc wired in parallel for 1 ohm rated at 1000wrms . it moves a lot of air through that port. its tuned to 30hz. I can remove the port and add different lengths to tune for any freq. I had this sub hooked up to my old Hafler xl280 (at 4 ohm) and after using the 3116 never went back. I'm sure the distortion is high but I can't tell at sub freq. After 5 years I am still amazed. I think I got the unicorn. I had it running my JL 10w7 at 3 ohm but it just didn't have the same output. It is a sealed enclosure, but I think it works best at 1ohm
- Class D
- TPA3116 on 1 ohm load
